03-24-2009, 08:26 AM
Buying my 1st Dnano
Hello all, I have decided to buy my first Dnano. but before i do, there are a few things I need clarified.
Are the instructions in english ?
Are you able to drive more than 1 car with a single controller? not at the same time obviously.
Last but not least, how long is the run time and charge time?
Cheers
03-24-2009, 09:06 AM
any company that puts out any product without english is asking for failure... thats a no-brainer. 2, yes... the radio is 2.4gHz & is used exactly as a DSM transmitter/receiver would work... except the dnano's receiver is already built in (in short, u can bond ONE transmitter to as many models as you can afford). 3, run time is normally 15-25 minutes and charge time is less than 10 mins.
03-24-2009, 10:32 AM
srsly charge time is less than 10min? the ppl in the kyosho shop in hong kong saids tht charge for 30 mintues and it will run for 30 minutes?
03-24-2009, 04:54 PM
i don't know what they're using but using the stock charger & stock battery that come in the starter kit, you'll get charge/run times as i've quoted above.
03-24-2009, 07:23 PM
Obviously the runtime depends on how hard you are on the throttle, and the charge time depends on how depleted the battery was, but I would say my estimates are closer to Nanotrax's than the guys at the dNaNo shop in HK.
03-24-2009, 09:41 PM
thx for the information!
04-13-2009, 08:48 AM
Is there a built in low voltage cutoff in these or do you just have to be careful on your runtime?
04-13-2009, 01:59 PM
Someone said there isn't a LVC on dNano. I am not sure.
The car slows down abruptly, significantly.= time to charge.
dNano - Corvette (04/10).
