I'm having the same problem. I've been to my local hobby shop 2X, done a little trouble shooting myself & hit up the Losi website for info. (note: I also have a Micro baja w/ no probs)
Here's what I know so far:
First visit to hobbyshop loosened up tranny a bit, problem got better, but still persists.
Second visit to hobbyshop, second tech broke down the tranny & found nothing. Tech agreed that the tranny sounds 'wrong'. We both agree that something in the tranny is bunk because when you free spin one rear wheel they both turn in the same direction. Shop was closing, it's a holiday weekend, both agreed to do research on the web & contact Losi on Tue.
Spent the night changing the springs on my Baja & installing bearings. Also broke down the entire tranny on the Micro-T because it was just bugging me that we didn't know the prob. Nothing seems out of whack, but I found both the diff bearings to be sluggish & squeaky. A bearing shouldn't be noisy at all, unless it is bad. I believe I found the problem. $3.00 for new diff bearings on this site. Left everything disassembled for further review at the hobbyshop during round 3.
Looked at the Losi website & nothing about this type of problem is mentioned anywhere. However I noted that the Micro-T instructions tell you to loosen up your tranny. I should've thought about this. Any experienced R/C'er will check things on an RTR like the slipper clutch & make any necessary adjustments before actually running. Lesson re-learned, I guess.
I should mention that I have the LiPo in both vehicles & man that Baja screams! You just can't turn the darn thing at full tilt! Run times w/ the stock batt are just pathetic, but you better have some driving skill if you upgrade to the LiPo or this will quickly become as expensive as the larger scales.
I will post up more info & the actual solution if/when I get it.
