Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 11-11-2007, 02:15 PM
cory b cory b is offline
transmission problem
i keep chewing up mainshaft bushings,in my micro baja. any help would be great.
Old 12-04-2007, 07:25 PM
Thumbs down
thanks 4 the help
Old 06-16-2008, 06:27 PM
sk8r's Avatar
sk8r sk8r is offline
Hey bro, try putting sum type of sealent (jb kwik weld reccomended) put sum on the driveshafts lockin evrything togethr, i just did it and it works great!!!!!
Don't talk about it, be about it!!!!
Here is a link to a site that a friend of mine started and we are tryin to get ppl to join so here's a link-http://rcaddicts.darkbb.com/portal.htm
Old 05-28-2009, 04:10 PM
small=breakable small=breakable is offline
So when the bushing gets worn out the spur gear becomes wobbly? The fix is buying an aluminum gearbox. Most preferably 3r brand. Instead of the bushing it uses a bearing. This will not wear down much at all and increase your runtime a bit. Read on microtforum.com. everyone who has had this problem turns to that gear housing. You will need to read how to shim the diff gear or watch this vid. It tightens the gears so they dont strip. To big of a wire or washer and it will bind up.
http://www.youtube.com/watch?v=DeUVd...eature=channel
This shows how to make a good shim.
Z car transmission problem? rikc Atomic Z-Cars 0 02-21-2005 11:59 AM
Serious Problem... Pocket_Rocket XMODS Parts and Hop-Ups 10 11-08-2003 04:02 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
