Old 04-10-2007, 07:01 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Can I just use a resistor on of the motor leads to speed it down a bit or is there another trick I can use?
Yes, a resister will work. You could also use a potentiometer or variable resister so you can dial in the speed you want.
Old 04-10-2007, 10:41 PM
jevries jevries is offline
thanks for you reply! I will try to find an appropriate resisitor...the variable on sounds even better but I hope to find one that small.
I will post pics of my 1/64 (s)lowrider soon!
Old 08-17-2007, 07:58 PM
fatman's Avatar
fatman fatman is offline
cool
well u could change fets to but it will work ether way good luck
if its not broke i can fix it
Old 08-17-2007, 11:47 PM
Smile
Thanks for your reply!
The transistors do there job well, but changing fet's indeed is a good option as well.
Old 08-18-2007, 12:45 PM
fatman's Avatar
no prob
if u have any prob i can help i have many answers and questions but still great
A question about batteries. steelo Miscellaneous Discussion 2 09-17-2006 01:42 PM
lithium batteries J-Tuner XMODS Parts and Hop-Ups 13 01-14-2005 08:49 AM
Question about li-poly batteries... BryceOwen XMODS Mods and Projects 0 01-18-2004 01:42 AM
Rechargable AA batteries in Charger Question SuperSupra Bit Char-G / MicroSizers 9 08-08-2002 03:22 PM
