04-28-2007, 04:14 PM
ZipZap not working
I found my old ZipZap, a red Dodge (Viper?), in my closet(I haven't used it in atleast a year) and decided to see if it still worked. I turned on the controller, the light was green, and then put on my car on to charge. When I did, the light blinked red about 30 times, then turned a yellowish color. I put in on my table, but it wouldn't move and the lights don't work. The car is on (that was the first thing I checked). I assume it's not the AAA batteries, because the light on the controller works. Is there something wrong with the car?
04-30-2007, 12:19 PM
Is this an SE? If so, you have to make sure to turn the car on on the bottom of the car before you put it on the charger.
08-08-2007, 09:44 PM
umm read the manual cuz i read manual al da time it says that if the red light stops blinking, and the light turns amber (yellowish) it means there's a prob with the zip zaps. make sure it's on if it SE and make sure you connect properly lol i think that it but read the troubleshooting in manual.
08-09-2007, 08:01 AM
its gargege
i messed with it in yellow and it stalls if u take car off
08-17-2007, 01:10 PM
I process, therefore I am
I'd say the car's internal rechargeable battery is history. If you have another car, try switching out the batteries. Other than that, you'll have to find a source for a new battery for the car. The internal batteries go flat when stored for a long period and sometimes can't be recharged.
08-17-2007, 07:50 PM
noooo
dont id switch some parts lower chip and get a 150mah not 12o mah there cheap but semi hard 2 find
