Old 07-26-2007, 06:23 PM
outlaw892 outlaw892 is offline
Smile just a few questions
Are there any SE's that come with the original controllers? I don't particularly like the wheel. If so, which ones?
Also, based on what I've read, I've come under the impression that the SE's will work fine for what I intend to do. This being putting a 3.8 motor for maximum torque and top speed, two standard size batteries for maximum playtime, and the 7/7 mod for maximum steering. Am I correct in my assumption, or should I reconsider the original ZZ's, or perhaps even another model? Also, are there any better alternatives to the things I want to do?
Thanks in advance,
Eric.
Old 07-27-2007, 08:07 PM
rody rody is offline
I don't think they come that way. SE's have semi-proportional steering, which needs the wheel in order to make it's clicks. The original Zips have either on or off steering using magnets. I suppose if you have the will, and knowlege, you could mod the controller to work how you want it to. A good compromise would be to use the Car's or Transformer chassis Zips. IMO, these are the best Zips that have come out yet. They're faster, able to use the lights, and the controllers have the nicest feel.
Old 07-28-2007, 06:44 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Newer SEs disn't need the 7/7 mod. Unless you have some SEs that need the mod, I wouldn't worry about it.
As to longer runtime, I'm not sure standard batteries are the answer due to weight. What size were you considering? Another option if cost isn't a factor, would be LiPos, and a good charger.
Old 08-06-2007, 06:54 PM
fatman's Avatar
fatman fatman is offline
Talking mater, lightning,sally,optimus, and bumble bee
have the effects of se's without the controller and no pesky on or off switch
if its not broke i can fix it
SE Steering Questions Azimov ZipZaps SE 49 02-04-2004 12:11 AM
questions questions questions kasper01001 XMODS 12 01-02-2004 05:38 PM
Bit-Dub Conversion questions mcojoc Bit Char-G / MicroSizers 0 09-25-2003 12:49 PM
Questions for Ahh5hit 55_BrOoKs_55 ZipZaps 8 08-25-2003 08:27 PM
Mini-x tech questions Bravin Neff Mini-X 27 12-28-2002 04:25 PM
