05-10-2007, 09:06 AM
My Custom - Micro T + Case + Ramps
The Case:
As u all know, micro T's don't come with a case to keep them in when your not using them or when u are taking them out with u... so I though I would make my own... and here it is...
I made a mesh tray, which I painted black to sit the batteries on while they charge... I also added a 40x40mm PC, powered via a 9v PP9 battery, which will kool the motor down between runs...
The Micro T :
now for the micro T side of things... my current spec is:
- Atomicmods bb motor
- ball bearings
- alloy shock set
- alloy front skid plate
- threaded steel Wheel shaft shafts
and of cause, the custom hard plastic body, which as u can see I am still working on... lol...
the body I got from a 1/32 nissan king cab - Tamiya kit... which I have had to cut the rear cab out of to make the body lenght shorter to fit the micro T's wheel base...
The Ramps:
Here is a pic of my frist 2 ramps I made from cereal boxes...
I will get some vidz made, once my new servo gets here from the USA, probs next week...
I will also update, again once I have more work done on the body and my new rims set on it...
05-10-2007, 11:00 PM
Looks great, did you make the wood case?
05-25-2007, 08:26 AM
no... it was an old art box, which I made new spacers for...
updates added a better longer aerial, along with the new rims and another body, which I will use along with the custom one, once I get it finished... lol...
I also made some spacers to stop the adjustable o-ring slipping back up to the top, on the HR shocks... I kut up some spare tubing from RC aerial to make the spacers with...
after seeing a tut Suzuki did using some plastic tubing from wire end connectors...
Below is a black widow spider design I did, which I will print onto some decal paper for the sides of the above body...
06-30-2007, 09:23 AM
update time: I have a clear baja body that I still need to kut and mount, will get a photo of that up soon...
but what I do have is new photos of my micro t's chassis...
I also made some new jumps/ramps... I made 2 of the one u can see my micro t on in the below photos...
New Specs/ Parts list for the above micro t :
- Ball bearings
- HR Alloy shock set (Blue Springs)
- HR Alloy front skid plate
- Threaded steel Wheel shafts
- GPM Alloy Camber Links
- GPM Alloy Rear Arms
- HR Alloy Front Arms
- HR Alloy Silver Ovals Rims 0ff/set
- HR Front shock damper tower
- GPM Rear shock damper tower
- HR Losi Micro T Silver/blue Aluminum main chassis
I am wroking on a newer smaller aluminum case, along with a new video, so I will update again soon...
06-30-2007, 09:43 PM
That is one dead-sexy T !!
Very nice.
07-01-2007, 09:11 AM
thanks!
08-11-2007, 09:20 AM
Here is a few pics of my micro t with its new wheels, which are made by Technical Racing Products, I found my set on ebay spain...
08-12-2007, 03:25 PM
TinyRC & Mini-zRacer Fan
damn, thats a nice looking micro-t! if you don't mind me asking, how much performance gets sapped by all the aluminum weight?
11-30-2007, 04:56 AM
