Old 03-22-2007, 12:05 AM
Ottobon Ottobon is offline
Car will only move on charger?
Just got my first Zip Zap, a 04 NSX, ill be getting some SEs soon, but it would be nice if this thing would work
anyways the car seems almost like it wont charge or something, the light on the controller is always green, and i can only get it to steer and or accel/reverse the first few seconds its on the charger
is my car broken?
atleast i love the way the NSX body looks , hopefully my SE models wont be so broken when i get them in in a few days
Old 03-24-2007, 08:35 PM
Drifter39 Drifter39 is offline
I have a car with the same problem, I have found out that it's the cars internal battery. It has gone bad. There not too hard to replace, the only problem is trying to find a replacement battery.
Hope this helps.
Old 03-25-2007, 01:38 AM
it does, strangely i've found some of my cars seem to just be strait out quicker and more responsive then other cars, ill assume thats the same issue
do i need to make any modifications to get a regular Zip Zap body to fit onto a SE chassi?
Old 03-25-2007, 07:08 AM
Nope, no adjustments needed, that's the neat thing about them. I have three regular cars and one SE, and I swap bodies all the time.
Most SE bodies do have hook ups for lights or in some cases, music, there is a set of SE bodies out there, Cadillacs I think, that actually play music when you run them around. and of course, there pretty hard to find.
Regular zips don't have any hookups for lights or sound, but you should still be able to switch the bodies around.
Hope this helps.
Old 03-26-2007, 11:22 AM
rody rody is offline
I've also found that if you charge them a fewof times (wait until the light turns green) without them running off the charger, that the batteries come back to life, and they start working as normal again. Just make sure you have fresh batteries in your controller.
Old 03-26-2007, 03:59 PM
Thanks for the tip. Too late for mine, I pulled it out and trashed it. Sigh...
car wont move?? dolfan03 XMODS 5 02-28-2004 01:39 PM
The charger isn't that special!(IC-3s) Char-g Ace XMODS 33 02-11-2004 09:36 AM
Initial D is addictive zombiebaby Bit Char-G / MicroSizers 96 07-20-2003 01:31 AM
Rally car gallery crazydave Bit Char-G Gallery 34 06-07-2003 09:58 PM
Auto Charger Bryan4691 Bit Char-G / MicroSizers 13 12-18-2002 11:01 AM
