The closest thing to a problem on the car side would be that 7.4 volts is a bit hard on the motor, so I drilled a small com-drop hole in my end-bell and every now and then give it a drop with a small syringe to keep from carbon coating the com, so far it seems to be working.
Hi. I'm thinking about buying one of these Micro-T's and putting a Li-Ion battery in it. But first, I have a few questions:
How does a 3.7v 2P pack work since the ESC requires 4.8v?
Is there a 3.7v 2P pack on batteryspace?
Which one of these PCB's should I use? They limit the current draw from 5v up to 9v and I don't know which would be best for a 7.2v 2c pack. What about for a 3.7v 2p pack?
Will you post a pic of the comm drop hole you drilled so I know where to drill mine?
Lastly, how often do you add drops?
Thanks for all your help!
Reason: Forgot to include a couple of my questions
