A fellow member was kind enough to send me one of these little jewels and I just love it. These things are the natural next step in improving the Zip Zap line of micros. They are much more to scale as being slightly larger allows the wheels to look more proportionate to the body. The removable wheels are the single best modification on the chassis. Removing lint and hair is no problem on these MicroZ GTs. The steering on mine is smooth and strong. I can't discern any actual steps when I watch it turn. It just seems to just move more and more as I turn the wheel. No stuttering at all. I wish these things would come to the US. I guess the Canadians are first this time around. Kindof a payback for having to wait for Zips a few years ago, lol.
then after the antenna extention the range just dropped down to less than 1 foot
I'm not familiar with this mod. I'm assuming you just soldered a new, longer antenna on the thing.
First, be absolutely sure all connections are good. A cold solder joint may look great, but have a lousy connection. If all is solid, I would next suspect that you have an improper length of antenna. The RX is tuned to the factory length which is an even fraction of the actual length needed to recieve the signal the strongest. Which is the actual length of the radio wave measured from the top of the curve of one wave to the bottom of the next. I have no idea what that would be for 26.995MHz, but you don't have to have a slide rule to get close. You can find the antenna tuner on the PCB and turn it gradually with a small screwdriver, test, and repeat until you adjust to the new length of antenna. Or, you can add or subtract small lengths from the antenna, test range, and repeat until you get better range. Actually, a combination of the two is best, but snipping the antenna is the easiest. Of course, snipping til you reach the original factory length kinda negates the mod.
Still, I would put my money on a cold solder joint.
Range doesn't seem to be an issue on my MicroZ, so I'm not sure why you would mod to improve it, or is it an asthetic modification?
