Old 12-30-2006, 07:16 PM
Realuser Realuser is offline
Took zzmt apart, how do i put it together again?
Hi, im new here.
Refer to my thread:http://www.tinyrc.com/forums/showthread.php?t=22973
I took my zip zap mt apart(didnt disconnet any wires) and now i cant figure out how to put it back together. It fell apart before i saw how it WAS put together....
Is there a guide that can help me? This sucks
(its the very bottom part, the drive components)
UPDATE: I finally figured out how to put it back together, but im having trouble keeping the battery from interfering with the little white gear that moves left to right to turn the wheels. What should i do?
UPDATE TWO: I figured out how to keep the battery away, but now the steering isnt springing back in the striaght form, and sometimes gets stuck and wont swich directions. what should i do? I made sure the pin was between the little metal spring thing.
Old 12-30-2006, 07:52 PM
Jazz32
I would again make sure that the steering gear is placed between the legs of the steering spring. It might have slipped out or something. You can take out the steering motor and the two screws holding that one piece on rather than taking apart the bottom.
Old 12-30-2006, 08:02 PM
Okay i will do that, it is also having very bad turning problems and it sounds liek the gears are skipping very bad.
Old 12-31-2006, 01:15 AM
Jazz32
One of the gears is probably out of place or something isn't tightened down properly. Make sure that the turning motor is all the way down as well.
Old 12-31-2006, 03:27 AM
Okay i got it a while back. Not sure what the prblem was but it is fixed. Now to another problem, IT NEVER ENDS!
My battery seems to be pooping out. Im getting much less time to run it after a charge and its going slower and has less torque. Suggestions?
Old 12-31-2006, 03:29 PM
Jazz32
Put new batteries in the controller or charge it for more than one cycle.
My Z can use the ZZMT controller 'Vette Nerd Atomic Z-Cars 8 06-01-2006 01:16 PM
ZZMT Stuttering zzultimate ZipZaps Monster Truck 6 04-18-2006 11:33 AM
A little Dragon Power, don’t kill it put it to work! LBRC ZipZaps Monster Truck 6 03-17-2005 05:26 PM
Put all your SuperSlick reviews here. charliebrown SuperSlicks 1 01-29-2004 06:38 PM
