10-25-2002, 02:14 PM
Livin' 22 feet at a time.
Question, please awnser quickly.
I have a question. I just purchased a RX7 Micro Sizer... I just saw that the Zip Zaps came out and I thought this question.
Will Zip Zap bodies fit on a Microsizer frame?
I wanna buy the Fast and the Furious body kits but dont feel like getting a whole new car, can someone awnser my question?
Thanks,
(sorry new to this)
10-25-2002, 02:19 PM
I'm with stupid^
nope. Zip-Zaps are a little longer that Microsizers so the body would be too long for it.
10-25-2002, 02:59 PM
I just bought a Fast and the Furious upgrade kit for S's and G's.
Can I use any of the parts that came with it on my Bit Charg? the motor, gears, anything?
10-25-2002, 03:08 PM
Life's a... Bits
Definately you can use the tyres and the motor, but I don't remember what else has the FnF set in.
Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
10-25-2002, 03:23 PM
Can I also use the gears, wheel base axel, and suspension?
Ok... I get my BC RX-7 in the mail on Monday. I wonder if there is some way that I could mod the Zip-Zap body to fit on it... any ideas?
Which cars do you think is better. If i went out and bought a Zip-Zap starter kit and put all these parts on it. Or just put what I have on the RX7 when it comes.
10-25-2002, 04:12 PM
Life's a... Bits
Yes, you can use the suspension and the gears but the axle I think is longer than the Bits' axle.
10-25-2002, 04:34 PM
Actually, everything except for the heatsink and body are compatible with the char-g.
10-25-2002, 05:10 PM
Life's a... Bits
Are you sure?
Because the back axle of the ZZs is longer than the Bits I heard
10-25-2002, 07:15 PM
Anyway
Anyway you guys think I could mod the body to fit my BC? If not Ill just buy a Zip-Zap and have 2 running cars.
I just love this Eclipse body and wanna put it on my BC... if not...no big.
Where can I get it off the net. It says "Only at Radio Shack." But like all the ones around here have none.
Custom Castrol Tom's Supra V.2.0
3.8 OEM Motor
2 Stage Booster Mod
Blue Gear
Blue Axel
Level 3 Suspension
AOL AIM: Turkish 0099 ADD ME!
10-25-2002, 07:50 PM
I am positive that the gears fit, since I was using the ZZ gears on my bit.
10-25-2002, 08:04 PM
Life's a... Bits
Im not speaking about the gears but, about the back axle.
Bits' Axle is shorter than that of the ZZs.
Anyway...
10-25-2002, 08:29 PM
Well
As soon as my Radio Shack actually restocks on ZZ's... Ill go buy some starter kits and hopefully they will have the Supra body kit in, I want it really bad. So when they restock I should have.......
ZZ Eclipse fully upgraded
ZZ Supra fully upgraded
BC RX7 fully upgraded
with left over parts including ZZ RX7 and ZZ Civic body
Anyone know where I can just get like a main body... like the chip and battery with everything for ZZ's?
3.8 OEM Motor
2 Stage Booster Mod
Blue Gear
Blue Axel
Level 3 Suspension
10-25-2002, 08:34 PM
Well, I meant the gear and axle set.
If you cant get your hands on a supra bod, I have a supra bod that I could send you. With the wings. Rims if I could find them, lost em in the carpet.
10-25-2002, 08:45 PM
All the radio shacks around here are also sold out of ZZ's. Im using the NOS and turbo motors from my ZZ in my bit now, and also the gearing and axel. The axel is the same size of the bits and is a perfect fit. The ZZ motors are alot faster and have more torque in a bit than in a ZZ, because the bits board is better, allowing more current to the motor. I wouldnt waste your $$ on a ZZ when bits are alot faster. The fast and furious bodies look pretty cool tho, but they are alot heavier than bit bodies, and with the shorter wheelbase of the bit, I doubt you could get a ZZ body to line up with the wheels even if you do get it to fit.
-Vince
10-25-2002, 08:51 PM
Mega: Just extra stuff you wanted to give me or for $$$$$$ (sorry I am new to this stuff) Is it a Supra body for ZZ or BC?
I might just get a single ZZ and upgrade it fully so I can use all the FaF bodies on a decent car. And keep the BC for another car. Basically I woudlnt mind have 2 fully upgraded cars I can mod over time (2 diff. mhz of course) and have various bodies I can swap on and off of them.
3.8 OEM Motor
2 Stage Booster Mod
Blue Gear
Blue Axel
Level 3 Suspension
