Truck Tires
My truck has completely erased the tread on it's rear tires. I rotated the tires 2 weeks into owning it due to wear showing in the back and none at all in the front. 3 weeks later, the rears are completely bald, with one showing an odd gouge around half it's circumference. This thing is also uncontrollable with the throttle set on HI, which is where I like to drive it at. It's completely stock, running 1100MAH NI-MH AAAs for juice. What's the best place to get replacement tires that wont chew apart in a month? I like the grip of the stockers when they had tread, just not the wear. Running surfaces include rough and smooth asphalt, dirt, linoleum(Primary running surface), rough plywood, rough-textured concrete, thin and thick carpeting and pea gravel, so an aggressive pattern is a must. Thanks
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
