Old 10-28-2006, 03:53 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
the knuckles on my 1/32 bruiser uses a thick brass tubes, because i plan to use this truck through mud, those tamiya three speed gears are too big to work on, one reason why i ditch it off the truck and it's way too fast, well that's just my own opinion, i meant the gear ratio is so high that you could burn your esc easily or if your electronics could handle it.. your battery will run out of juice pretty quick!, just look at how close the size of the tamiya mini-4wd tires are compare to the main drive gear!.. gears are like tiny levers.., build your gear combinitions so you could maximize the space you need for your electronics.
hehehe
Old 11-21-2006, 06:40 PM
wheelhaus
This is awesome information. I'd like to build a 1/35 scale (or smaller) TTTT and plan on fabricating most of my own parts. my first attempt will most likely have a simple shaft wo a RWD worm gear, front steering, and articulation on both axles. Seeing your ideas is very motivating.
The idea of using small brass tubes for U-jounts is ingenious! That really opens up the possibilities... What do you use for the spindle block, just a small brass block with a couple pressed pins?
I assume most of your fabrication is done with small hand files and tiny fingertip drills.
Old 01-21-2007, 07:56 AM
Bodie Jr Bodie Jr is offline
Killer....Wassup bro! Awsome work as always.
The "Living Room Basher" is still kicking btw.
Keep up the awsome work,
Cya,
Bodie
Tamiya Tamtechs fastmax Tamiya M-Chassis 5 10-29-2007 11:39 AM
FS NIB TL-01 Tamiya XB FORD F150 Lightning 4wd RTR Set kylelucas For Sale/Trade 2 10-28-2004 05:39 AM
can someone find the full version of this video? 323iT Bit Char-G Gallery 3 11-04-2002 12:16 PM
Tamiya Championship Series slotsurfer Tamiya M-Chassis 5 09-28-2002 08:02 PM
