Old 09-16-2006, 08:21 AM
NEO-R NEO-R is offline
W-where did you get these!?
Where did the time go?
Old 09-23-2006, 04:58 PM
whuuht whuuht is offline
Talking
hooked some EL wire that i bought from the dollar tree a while ago hahaha but i havent seen anymore there but if you do find them there supposed to hook up to your real car for the intereor or whatever?
Old 10-10-2006, 03:17 AM
dj_miracle dj_miracle is offline
Hi Guys ;-)
I decided to paint my XMods drifter like my real life "drift pig"
Mods so far:
Bomex Bodykit
Command Lights
Xmods shocks/springs upgrade
Mabuchi FF-180SH w/ 11 teeth (Toothbrush mod)
6 Cell Upgrade (7,4V)
1000mAH Ni-MH rechargeables
Monoshock at the rear axle
Painted Lime green / flat black
Reversed rear rims
Waiting for delivery:
- TOPCAD Alum 7-Spokes Frt & Rear Tire & Wheel
- Complete Alum. Hop-Up set including:
1. Titanium Center Shaft
2. Front Gear Box
3. Rear Gear Box
4. Motor Heat Sink Mount
5. Front Knuckle Arm
6. Front Gear Differential Joint (4WD)
7. Rear Gear Box Diff Shaft
8. Steering Plate (0 Deg)
9. Steering Plate (1 Deg)
10. Steering Plate (2 Deg)
11. Center Shaft Holder
12. Front Damper
13. Rear Damper
14. Front Upper Arm
15. Rear Lower Arm
16. Battery Heat Sink
17. Graphite Front & Rear Upper Plate
18. Wheel Nuts
19. Ball Bearing Set
- Lithium Pro Kit 7.4v 750mAH
Drift pig:
Old 10-10-2006, 07:43 AM
ooh, an S-14...nift! To me, they look alot like an R33 skyline coupe (GT-R/GT-S), but that's just my opinion, not yours. Get your own opinion...
Old 10-22-2006, 06:27 PM
musclecars4life
thats not too bad. the black is a little flat though.
thats a nice car u got.
Old 10-23-2006, 01:03 AM
Thanks guys
Still waiting for my Alu parts, but installed the Lith pro Kit, a clear chassis, stacked my FETs, did the tight turns, mounted brake discs and bypassed the power switch. Let's see whats next
Old 10-27-2006, 07:04 AM
Here are some updated pictures:
Old 08-30-2007, 05:40 AM
skylinedriver's Avatar
skylinedriver skylinedriver is offline
Nissan Skyline
Here are some pics of my Skyline and chassis
This is a pic when I first got the GT-R chassis
Old 08-30-2007, 08:29 AM
fatman's Avatar
fatman fatman is offline
sick
but i would have put a gray on no carbfiber style and would put a deep dark red
if its not broke i can fix it
Skyline Gallery 323iT Bit Char-G Gallery 424 08-03-2012 05:40 PM
Skyline gallery...Post pics here. Bad Company ZipZaps Gallery 22 10-17-2003 11:26 AM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 10:26 PM
