07-01-2006, 11:26 PM
Originally posted by eetoi
but will it work for Evos?
Yes, they will work for evos
Drivers Wanted.
07-02-2006, 08:53 AM
(insert something funny)
fo the evo do you have any pics of what the forward fet is and the reverse fet is
07-27-2006, 03:29 PM
k i acidentally installed the 7329 fet in the 9910 spot and i still was able to steer that means electricity was flowing through my xmod so instead of taking out the 7329 shud i just leav it there and install the 9910 in the 7329 spot
oh also just wondering could i stack 3 9910's with only two 7329's
09-09-2006, 05:25 PM
Fet Mod Schematic and Layout
Hey all,
I'm new here but I just wanted to share this with y'all. This circuit is basically the same one RacinSkillZ101 posted some time ago and also the same circuit as Neuro's except with a 5v regulator. Anyhow, I made a layout and schematic for it so I could attach it to my xmod and thought I'd post it in case anyone was interested.
Some points of interest first:
1) I've flipped the Fets sothat they can be flattened against the board heatsink up. This is so I can blow air from an intake over them.
2) The IRF's are 4905's, IRL's are 3705's and the regulator is a LM7805.
b=battery
m=motor
and the -# after the IC's is the pin pad to connect to.
09-09-2006, 05:31 PM
Here's the Layout
Insert this layout gif into a word doc and resize it to:
W=1.36"
H=2.23"
Then get a sheet of labels, peel off all the labels and print you doc onto the shiny side of the sheet with a laser jet printer. Then you'll be able to transfer the circuit onto a blank PCB with an iron. Notice the image is inverted.
09-09-2006, 06:06 PM
BTW
cc+ and cc- are power and ground for the xmod's circuit board.
09-10-2006, 10:59 PM
I process, therefore I am
Very good and thorough info! Thank you very much.
09-12-2006, 05:30 PM
Woops
This is the corrected PCB layout...sorry bout that.
10-16-2006, 07:53 PM
Banned
hey nice work, im going to receive some money from school later in the month, when I do I will pick up an EVO xmod, no mods just want to get back to driving these things, I will test out my frankenstein electronics, vids to come once the winter months roll in.
08-18-2007, 06:18 PM
yes
it is the riite layout
