Old 10-31-2003, 04:40 PM
Nii Nii is offline
Where do u get test leads and how much do they cost?
Old 10-31-2003, 07:12 PM
I have a beach ball...
Radio Shack sells battery holders and alligator clips.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-11-2003, 08:21 PM
colin4371 colin4371 is offline
PPG Co-Owner
by having it submerged in water, but not touching anything, should it be touching the bottom/sides of the container of water?
i just wire it up to a battery pack that is high and dry, correct?
Old 11-14-2003, 02:47 PM
PPG Co-Owner
so thats all i do?
Old 01-16-2004, 03:35 AM
rcguy
i did a complete "how to" on this subject on another site. anyone want the link? i don't recommend using wd-40. it will eventually gum up.and slow the motor down. i recommend using compressed air,or motor spray to dry the motor. the wd-40 is also responsible for some of the increase in rpm. it is actually lubricating the comm/brush area. if you run in a dirty/dusty area,your motor will turn into a dust bunny using wd-40. i like to use either mobil1 synthetic oil,or prolong lube in the needle applicator on the bushings (motor bushings) only. any lube on the comm,and it gets dirty quick. you want the comm/brush contact area as clean as possible.
Old 01-24-2004, 07:19 PM
food123 food123 is offline
after running my xmod for a while, I've noticed black gunk starting to show up on the gears. an ideas on how to clean them?
also- is there any need to re-oil the drive shaft after taking it out? if so, how?
Old 01-24-2004, 08:18 PM
rcguy
you should never need to oil the driveshaft.to clean the gears,just use an old toothbrush that you don't use on your teeth anymore.be sure to take the gears out of the car first.
Old 01-24-2004, 11:14 PM
cool. thanks. that had been bugging me
Old 04-25-2006, 09:37 PM
x-modsrocks x-modsrocks is offline
Yes rcguy i would like a link
Member's collection of painting tips. suprafreak33 XMODS Mods and Projects 26 04-26-2007 04:15 PM
radioshack racing series tips 10_second_supra XMODS 24 02-23-2004 12:32 AM
traction tips aero528 XMODS 19 11-20-2003 09:25 PM
PCB swap tips Bunta ZipZaps 0 10-23-2002 09:57 PM
place ur tips here!! lanevo7 Bit Char-G / MicroSizers 18 10-22-2002 06:31 PM
