Old 06-20-2003, 11:32 PM
Ovgron's Avatar
Ovgron Ovgron is offline
I own you
im going to make a micro mosnter truck (made from a bit char-g) and i was wondering if you could post a pic of it without the body so i get a idea for suspension.
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
Old 06-21-2003, 10:17 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
:ö: yes i have a pic of that truck without the body... it's on my gallery at the TTTT thread here.... hope to see some pics of your project truck too .
hehehe
Old 11-28-2003, 07:19 PM
sawhit4 sawhit4 is offline
hey killer could you please do a thread on how to make those awesome u joints? they are SWEET. i want to try to make a truck like yours if your cool with me using some of your ideas. thanks alot
Old 12-15-2003, 09:30 PM
lowam lowam is offline
i didnt see any pics in the tttt forum. is there any way you can post some more of the mini bruiser chassis. im trying to figure out how to build some driveshafts for myself thanks
Old 12-15-2003, 10:23 PM
killer's Avatar
it's there!.. but to save your time from looking, here it is .. this one has a 130 type motor with a 5:1 gear ratio from a Tamiya Mini-4WD chassis.
hehehe
Old 12-15-2003, 10:28 PM
killer's Avatar
and here's the one i use, powered by a Modified to accept micro servo Mini-Z racer electronic board,4cell Ni-Mh battery and a smaller motor, i lower the gear ratio to 150:1 so i can use a smaller motor, but the 5:1 of Tamiya Mini-4WD is too high even if i use a Modified High Torque 130 motor.
hehehe
Old 12-16-2003, 02:20 PM
how do you solder brass like that . its really cool . i'd like to learn how to do that.
Old 12-19-2003, 03:22 AM
killer's Avatar
:ö: to solder brass.... well, this is how i do it
first make sure that the brass you are going to solder is clean, no lamination or cover... and then use a fine grit sandpaper only on the parts to be soldered, apply a liberal amount of flux on both parts then hold them firmly together, using a third hand is the best way to this (this is a tool with two alligator clips and an optional lens), use a 60watts or higher soldering iron... melt just enough soldering lead on the tip of the iron, then touch the parts of the brass (with flux) to be soldered (make sure that the iron is very hot) you will see that the soldering lead will flow cleanly on the parts to be joinned .
hehehe
Old 01-02-2004, 08:43 PM
Bkast Bkast is offline
How much do you think it would run me to build something like that.... I dont know if I could ...wonder if you could hook me up with some u joints and other parts.
Brett
Old 02-20-2006, 04:13 PM
buffalo beans buffalo beans is offline
hey killer those are awsome i would like to make my self one but I'll need some tips and pointers if it is ok with u
and those u joint those are cool how did you make those Im going to make one Im just going to need some help doing it
Old 02-21-2006, 05:12 PM
just a suggestion these posts are dating in 2002. That's 4 years he's likly not to reply
Old 03-22-2006, 04:44 AM
killer's Avatar
am back!!!!.. whew!,actually those u-joints are handcrafted from tamiya 3mm (for 1/87 truck truck) and 4mm (for my 1/32 and 1/24 monster truck) actually it's the same as the u-joint on 1/10 scale rc cars!
hehehe
Old 07-29-2006, 02:51 PM
lphlp lphlp is offline
i know this is an old thread but i just found it and i have to say:
WOWZERZ!!!! man that little truck is awesome, i have been wanting to make something like that for quite some time now, the only thing that is stopping is not having those driveshafts that ur using to send powerto the axles....that little truck is amazing!!! wish i had one like that, in fact this just reinspired me,
thanks and cudos KILLER,
Lino
Old 07-29-2006, 05:54 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I'm glad you bumped this. Excellent work all around! I love this kinda stuff.
Old 07-29-2006, 07:23 PM
i found the oh so searchedfor U-joints!!!!! finally i can begin my creations!!!
here the link:
http://bearlocomotive.com/product/X0001
im just curious, is 6mm too thick for the 1/32 scale driveshaft u joints??? oh well....trial and error!!
-Lino
Tamiya Tamtechs fastmax Tamiya M-Chassis 5 10-29-2007 11:39 AM
FS NIB TL-01 Tamiya XB FORD F150 Lightning 4wd RTR Set kylelucas For Sale/Trade 2 10-28-2004 05:39 AM
can someone find the full version of this video? 323iT Bit Char-G Gallery 3 11-04-2002 12:16 PM
Tamiya Championship Series slotsurfer Tamiya M-Chassis 5 09-28-2002 08:02 PM
