Old 01-10-2006, 11:16 AM
Michael.mt2k's Avatar
Another old modder.
Project: Tri-Cell
After building a couple of decent crawlers I decided to go the other direction: Speed.
As mods go, this isn't new, but I hadn't tried it before, and wanted to see how performance would be.
Old 01-10-2006, 11:25 AM
Another old modder.
Ridiculously fast is how I would term it!
I'm doing the classic trick of hard-wiring the charging base to the batteries inside my controller to charge it. (manually timed)
I think this is the permanent home of that green Mustang body too.
Specs follow:
Tri-Cell
27Hmz
Green Cat5 Antenna
Orange Motor and Gearset
Additional Series-Wired Battery
Silver Wheels and Tires from Upgrade Kit
Suspension Drillouts
Athearn Springs
Upgraded Red ZZ Steering Motor
Old 01-17-2006, 03:34 PM
Warrior Warrior is offline
can u send me the directions on how you did the tri-cell because my truck batt. dosent last long at all.
and will u need a different charger to charge your tri-cell??
thanks
Old 01-17-2006, 05:23 PM
grimmreap3r grimmreap3r is offline
Yea. If you want that 3rd cell to give you extra power then you need a different charger.
like pizza
Old 01-17-2006, 05:55 PM
could you post a picture of the charger and can you just make one out of a zz controller
Old 01-17-2006, 06:18 PM
Posted by Michael.mt2k
You can make one out of a ZZMT controller but you will need to manually time the charge like what Michael wrote.
And also, you may want to add an extra cell to the controller to charge the battery to full capacity a little faster but you will need to manually time the charge. Im not sure how long to charge the MT with 3 cells(with 4 or 5 cell in ZZMT chargebase).
like pizza
Old 01-17-2006, 08:03 PM
thanks for the tips i really appreciate it. i just got a zzmt and did the gearing mod i like the results but my battery life is just too short, it only lasts like 30sec and then it cant move. would u prefre the tri cell or the quad cell???
Old 01-17-2006, 08:07 PM
High speed or low speed gearing mod?
And did you do any other modifications to your ZZMT?
like pizza
Old 01-17-2006, 08:10 PM
low speed mod thats the only one for now
Old 01-17-2006, 08:19 PM
Did you use new AAA batteries for the controller for your first charge on the MT?
It seems you have a bad batteries in your ZZMT
like pizza
Old 01-17-2006, 08:21 PM
yea but could you e-mail me the instructions on how you made that charger because i am new to this zzmts and how do you have to charge it manually
Old 01-22-2006, 06:34 AM
Another old modder.
Far be it from me to keep a post on track but...
I did the high speed gearing for my tri-cell hookup, along with the orange motor.
(I really wanted to see what this thing could do!
The rest of my mods are listed in the specs.
Old 01-22-2006, 06:37 AM
Another old modder.
A tri-cell MT will charge in about 30-40 seconds from 4 "AAA" batteries.
Count to 30 or 40 and you're good. No need spot-on accuracy.
Old 01-23-2006, 11:14 AM
thanks for the info... would u prefer quad cell or a tri cell and how long would u charge the quad cell.....?
Old 01-23-2006, 03:39 PM
Jazz32
I have 2 quad cells right now. The thing is wheelie crazy if you don't weight the front down. Both my of my quad cells have higher tooth pinion gears on the orange motor to gear it faster. This helps with the wheelies. They are also prone to role every time you try to turn at higher speeds. I tri-celled my younger brothers, and with orange gears, it's a lot more manageable. It all depends on what you're going for.
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 04:27 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 04:22 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 11:06 AM
