Old 10-06-2005, 02:14 PM
akura2's Avatar
akura2 akura2 is offline
Send a message via AIM to akura2 Send a message via Yahoo to akura2
***I need to know how to convert this servo into and ESC....
see pic:
I know there is a 5.5 and 2.2K resistor that has to be soldered on the board to replace the potentiometer... or something like that... but if someone could diagram this for me ASAP I'd appreciate it
Old 10-08-2005, 06:40 PM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
servo board mod!
try this set-up!
for more info on servo mod click here
hehehe
Old 10-09-2005, 08:25 PM
akura2's Avatar
all I see is a red "X".....
and BTW... when I went to that link... it showed the same diagram I saw in minizracer.com for arch2b.... but the servo PCB in that pic didn't have three wires for the potentiometer... mine has the three wires (yellow, green, and red)
Old 10-09-2005, 09:37 PM
killer's Avatar
look here
SCB right side*_red wire_________2.2k______
SCBcenter *___yellow wire________________)
SCB left side*__green wire__________2.2k___)
SCB =servo circuit board
2.2k= resistor
* =solder points
hehehe
Old 10-10-2005, 05:08 PM
akura2's Avatar
THANKS!!!!... that was exactly what I was looking for!!!
YAY
Old 10-11-2005, 06:51 PM
akura2's Avatar
now the only problem I'm having now is I can't get the ESC/servo to center/stop moving.... I've set all my trims and sub trims on my radio all the way in one direction and it keeps going in reverse.... until I hit the trigger..then it goes forward... but I can't get the neutral/stop point...
help
Old 10-12-2005, 05:28 PM
killer's Avatar
try re-arranging the wire set-up say your original set-up is like this:
try this..
SCB left side*__green wire________________)
SCBcenter *___yellow wire__________2.2k___)
or this..
SCBcenter *____yellow wire______2.2k____
SCB right side*_red wire________________)
SCB left side*__green wire________2.2k___)
unitl you hit the that sweet spot..
hehehe
Old 10-12-2005, 05:37 PM
killer's Avatar
or simply connect the wires on the resistor the way those wires from the servo board connected to the potentiometer!... see attached picture.. those colored dots represent the colored wires on your servo board
hehehe
Old 10-12-2005, 06:54 PM
akura2's Avatar
Thanks... that is the way it is in the first drawing...but I'll try switching the wires around... I didn't know that would make a difference...
wow...the things you learn online...
my soldering iron is heating up as we speak
Old 10-13-2005, 12:56 AM
killer's Avatar
one question.. does your servo board have a built-in 2.2k resistor connected to the potentiometer? if so, you have to use one 5.5k resistor and one 2.2k resistor, if not, then a two 2.2k resistor set-up is good enough... this set-up or what i call an upgrade eliminates the need for you to adjust or center the potentiometer everytime something hits or moved the adjustment knob, because those resistor act or is the same as a potentiometer on center/neutral spot.
hehehe
Old 10-13-2005, 03:15 PM
akura2's Avatar
My servo board is attached direct to the pot
but I just realized... I have a GWS Pico Standard servo and the board inside looks just like the one that Arch2B has...I'll work on that one now instead...
Thanks for all your help
**Edit... I used the other servo and it works GREAT!!!!!!!
thanks for your help (I ran two 2.2k in series instead of the one 5.4k... and after a few tweaks on the transmitter it centers perfectly and I have full propo control
Old 10-03-2006, 02:54 PM
88swampedmj 88swampedmj is offline
does anyone have a pic of this done? or could i just simply take out the elects. and wire the servo motor straight to my esc?
btw i have a hitec hs 85 that iam gonna use as a motor
never mind i just realized how to put the resistor on.. thanks for the help..
Old 10-03-2006, 03:40 PM
nice you just updated an old thread good job NO point in that GREAT
MOTORWORKS
[color=green]
Old 10-03-2006, 03:42 PM
hmm... i was just askin a question YA FREAKIN JERK...there was NO point you your dumbass post either .... go cry about it in the bathroom hahahaha
Old 10-03-2006, 03:50 PM
WOAH lookes like somone took kindergarten twice.
MOTORWORKS
[color=green]
