Go Back   TinyRC.com > 1/64 and Smaller > Table Top Truck Trials (TTTT) > TTTT Gallery
Old 10-02-2005, 10:31 AM
akura2's Avatar
akura2 akura2 is offline
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Check out this Terrain!
this is crazy... but very cool...all made from stacks of sheet foam
He who KNOWS he's stupid is actually kinda smart
Old 10-02-2005, 03:27 PM
TheMechanic
Thumbs up Terrain
Great job!
What did you use for the finish? Paint?
Old 10-03-2005, 11:13 AM
akura2's Avatar
Wish it was me... I found that pic on a German Bit/TTTT forum
www.bit-racer.de
Old 10-03-2005, 09:00 PM
diets diets is offline
The finish is made with
gypsum, mortal, cement, tile adhesive
bable fish doesn't help everytime
I don't know the correct word. Something to repair walls in your house. Something that is like powder and you have to mix with water.
Use a spray bottle with water and moisten the surface at little bit. Add some color concentrate to the water for a better finish. You can get it at your local hardware store.
Then put some powder on the wet surface. You will get best results, if you use a sieve (german "Sieb"). Let it dry/harden and repeat the whole procedure several times.
That's it.
diets - wish it was mine
Old 10-03-2005, 10:08 PM
akura2's Avatar
diets - wish it was mine [/b]
Plaster....or maybe spackle
Old 10-04-2005, 02:59 AM
pigeonfarmboy's Avatar
pigeonfarmboy pigeonfarmboy is offline
Go Banana!
I was at The Train Shack in Burbank today and found some really nice Woodland Scenics silicone rock molds. Picked up like 10 different ones along with some plaster and foam blocks. I'm waiting on the rest of the truck components but my MAN 5t is 50% done now. Then I'll measure the steering radius so the terrain can be custom made. Then I'll clear out some space in the garage so we can have a spot to drive.
Can't wait for our first SoCal TTTT Competition!!!
Old 10-04-2005, 04:30 PM
akura2's Avatar
My first Man 5T is 90% finished... I'm stil waiting for a speed controller from Germany (R500).and I have to figure out my steering linkage...and I'm done...check it out
Old 10-04-2005, 04:31 PM
akura2's Avatar
another
Old 10-04-2005, 05:12 PM
Nice work!
Now you need a TTTT modul
I only miss a pic from the bottom!
diets - ist immer ziemlich neugierig
Old 10-04-2005, 07:57 PM
akura2's Avatar
Here's the bottom... I just need to make it neater and maybe paint it... but the steering works.and that's the important part
still waiting for my ER500 Speedcontroller from mikroantriebe.de
(which seems like it's taking forever)
I want to possibly make a brass chassis for my next one
Old 10-04-2005, 08:28 PM
akura2's Avatar
post some pics of what you have done so far...
Old 10-05-2005, 12:46 AM
Go Banana!
Here it is. For now I'm trying to use the stock frame work but I don't know if I can make it work. I cut out a square hole in the bed for the servo to go through and mounted the servo with mounting tape on 2 sides. Then I had to notch out the top of the frame rail so the servo body would hang down low enough. I had to remove the middle wall of the cab for the receiver to fit. This is where I decided for future projects I definitely want to go IR. I plan to stuff the speed controller between the servo and the front of the bed. I had to take the back casing off the servo because the cover wouldn't mount flush. I might move the batteries up front because it's really rear-end heavy the way it is now. I'm going to try for 4wd on this but we'll see. Started on a brass frame with bad results. Soldering brass is tougher than I had expected. I'll have to crank up the iron and try again.
And finally a lil sumthin sumthin i got in the mail this morning!!
Old 10-05-2005, 08:26 PM
akura2's Avatar
Cool crane!!...
If you look at my earlier pics I was going to put the receiver in the cab (it fits perfectly...I just wish they made GWS surface receivers with JST connectors..it would fit better)
but i ended up putting the receiver in the rear by the tailgate.. and I might add lead weights in the cab to balance it out.. it will grip better while crawling if it's heavier so I'd rather add weight than shift it..
looking good so far Nate... what are you going to do about the steering/front axle? and the 4WD?
BTW.. I have the same computer tower... LOL
Old 10-05-2005, 08:38 PM
akura2's Avatar
BTW.. I'm also considering mounting the servo in the cab like this on my next one:
It's should make the steering linkage simpler...
Old 10-05-2005, 08:40 PM
akura2's Avatar
...or in the center..behind the cab...like this:
check this site! revenant Bit Char-G / MicroSizers 1 04-08-2003 09:05 PM
Check this stuff out!!! Impreza WR reX Bit Char-G Mods and Projects 7 02-02-2003 08:13 PM
come check out my web site anthonyb45 Bit Char-G / MicroSizers 1 01-04-2003 08:25 PM
combat terrain!!! GrEenGoBlIn Combat Digi Q 0 11-22-2002 09:41 PM
