Old 05-14-2005, 11:08 AM
kel kel is offline
Will the new pro stock be able to accomodate stacked FETs?
Old 05-14-2005, 06:24 PM
crazytom
Updates?
Any update on when they're going to be in stock? I'm just goin nuts waiting for it.. it's the last part I need for my "no stock parts" car (except for the front universal axel, gears, and supra body).
Old 05-14-2005, 09:09 PM
Zero-Man
Stacked FETS, just a simple dremel cut away, there are several chassis cut outs for ventilation in the middle area.......may be able to simply enlarge one or more to gain your clearance.
Wear your dust mask and safety googles, use masking tape around the area to minimize chipping.
I asked the Shop when they would be listed and here is the response, "It's on the list, s/b done by tomorrow at the latest! "
Old 05-15-2005, 06:33 PM
Zero-Man
Listed in the X-mods Shop!!!!!!!!!!!!! Get them while they are still in stock!!!!
Old 05-15-2005, 06:52 PM
FrEaK_aCcIdENT FrEaK_aCcIdENT is offline
just got mine ordered. thanx!!! waited and waited and waited! whats the status on how many u have left so far?
Old 05-15-2005, 09:05 PM
Zero-Man
It was quite a big order about double the previous orders, but I suspect the red Tex will depart early...........spread the word to the faithful that they are in stock at the moment..............I've bought some material so that I can do a re-up FAST, just in case.
Old 05-15-2005, 09:10 PM
dont worry i did and its only a metter of time b4 wicked gets on and sees his pm. if u had ant plans id like to see one in Ti silver color. like these bodykits for motorcycles. LOL but hey i know when im dreaming!!!
Old 05-15-2005, 09:15 PM
Zero-Man
Thanks!!
Titanium, that would be nice..............
Old 05-16-2005, 08:50 AM
eternaldragon eternaldragon is offline
Team Black Dragon
Send a message via AIM to eternaldragon Send a message via Yahoo to eternaldragon
will the x-frame pro-stock chassis accept lithium ion batteries?
thanks for any information.
Home of The Black Dragons Racng Team.
Old 05-16-2005, 12:38 PM
Horshu Horshu is offline
Obsessive Modder
Yes, it has holes underneath for ties, and quickconnect holders will also fit (even on a mid-chassis), although holding those things down is a challenge (I had to design some aluminum heatsink pieces to secure it)
Old 05-16-2005, 05:30 PM
Zero-Man
Yes it will but you'll have to modify the hardware some........That's why there is now an X Plus chassis, to accomodate all the different custom battery set-ups and aftermarket electronics packages.
Take a closer look at the pics and you'll see it's a pretty easy switch. Careful with 7.2V on the stock electronics...........
Old 05-16-2005, 06:54 PM
Team Black Dragon
thanks for the reply i was just making sure before i buy the chassis so i know what to expect. im running atomicmods v2.2 so the 7.2v is no problem.
Old 05-17-2005, 12:47 AM
chicken chicken is offline
Send a message via AIM to chicken
i see that the store has everything in stock now.thats kool.is there supposed to be the pro mod upgrade for the pro stock chassis? anyways i purchased it along with the prostock.cant wait to get it.i have a question now...can a 180 motor be used while in medium lenght chassis while using the hs-55 servo?
thanks
imChinOaChickeN
-imChinOaChickeN-
Old 05-17-2005, 08:14 AM
Zero-Man
I've got a stock Micro RS4 motor in with my HS-55 and have about 12mm left on the long chassis setting, so that should leave you about 8mm space on the mid setting, if the 180 is the same length...........hope this helps
Old 05-17-2005, 10:13 PM
thanks.that helps a lot.
later
imChinOaChickeN
-imChinOaChickeN-
Micro-T Carbon Fiber Chassis DAMZer Micro-T Parts and Hop-Ups 14 05-20-2010 06:57 AM
Carbon Fiber Chassis & Decks By XMODSource Are Finally Here! xodus XMODS 8 11-21-2004 07:08 AM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 07:17 PM
