Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 10-17-2002, 12:35 AM
togunter
squirrelly wrx
anyone have any tips for learning how to drive/fix a squirrelly red wrx?
really hard to drive it straight, its goes all over the place. i noticed that all 4 wheels are able to wobble a lot.
i guess i could get the digi propo special controller, but does it really make that much of a difference?
sure is fast though!
Old 10-20-2002, 10:39 PM
tinyrc's Avatar
tinyrc tinyrc is offline
I only have the Special Controller, so I'm not sure: does the stock controller have a trim adjustment?
Old 10-20-2002, 11:03 PM
gertman's Avatar
gertman gertman is offline
Yes, the stock remote does have a trim adjustment.
Maybe your Digi Q needs to be cleaned? My wheels wobble too, so don't worry .
-Engineering Manager
Old 10-21-2002, 11:49 AM
togunter
although there is a steering trim adjustment, there is no throttle trim on the stock controller. normally not a problem, but sometimes my throttle gets stuck and the neutral trigger position no longer means no throttle.
i think with regards to the squirrelliness of my car, my tires seem to be collecting a lot of dust, which makes them slip easily. plus a lot of the jumps and stuff on my track are made of business cards and scotch tape. the tape bits seem to make my digi q skid around a lot.
although my bit char gs handle the ramps/jumps just fine.
Old 10-23-2002, 12:00 AM
gertman's Avatar
Clean your tires with rubbing alcohol.
Sorry to inform you, but the Special controller doesn't have a throttle trim either.
Black WRX SupraCruza Bit Char-G / MicroSizers 8 04-24-2003 08:27 PM
Wrx? -v2oracle- Bit Char-G Gallery 3 02-11-2003 10:53 PM
the greatestt wrx mustangmainiac Bit Char-G Gallery 10 02-08-2003 07:53 PM
My WRX took a nose dive! Halo Bit Char-G / MicroSizers 10 10-25-2002 07:45 AM
WRX Decals SupraCruza Bit Char-G Mods and Projects 10 10-09-2002 02:43 PM
