Old 03-26-2005, 11:04 AM
Mr.M's Avatar
Mr.M Mr.M is offline
axle help
on a bit should the out side wheel ( the back axle wheel wiht out the gear) run not completely on? im say like sould the wheel move if i held the axle and move the wheel? like the car has a differintial? if not how can i take the wheel off? see my car dosent run strait ( and i have fixed with the front part ) and i think its the back axle.
Mr.M new and improved no lie'in
Old 03-26-2005, 03:33 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
yeah. It is the back axle causing it. I am not sure why they do that but they do. I fixed mine with super glue but I would probably just go buy another axle if I could have at the time (before microsizers came out in the US)
Best bet would be going out to buy a new axle set.
Old 03-26-2005, 04:32 PM
Mr.M's Avatar
no , ive got some glue thats expensive but its worth it. I'll just fix it with that and it will be good as new ... or .. umm like how it should be
Old 03-30-2005, 02:30 PM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
Why ?
Just glue it!
Don't try to glue it with the wheel on.
Twist and pull the wheel off, put a small drop on the wheel then replace the axle and let set til dry, install in chassis and you're good 2 go!
DarkTari
If It Don't Fly....."MODIFY"!
Old 03-30-2005, 03:19 PM
Racer9's Avatar
Tiny RC Pro
Mostly because It is so dang hard to pull the wheel off. I couldn't get it off but I used one of those fine tip super glue thingys.
Do whatever you see fit.
Old 03-31-2005, 06:14 PM
Mr.M's Avatar
but i did what DarkTari said take off the wheel and but glue on it and it is solid on the axle.
Old 03-31-2005, 08:27 PM
DarkTari's Avatar
BitPimp Enforcer
Ding Ding !
DarkTari
Old 07-23-2005, 04:41 AM
crazysk8r777
dont listen to dark tari hes gay/
Old 07-23-2005, 10:53 PM
DarkTari's Avatar
BitPimp Enforcer
See Ya Slick
DarkTari
Old 07-26-2005, 11:06 AM
DarkTari's Avatar
BitPimp Enforcer
Yeah Right
DarkTari
Rear Axle Bearing I-luv-Goin-Fast ZipZaps Mods and Projects 0 03-28-2005 01:58 PM
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
new and improved axle holder fix hogjowlz Bit Char-G / MicroSizers 1 03-04-2003 03:24 PM
heres a simple solution incase your rear axle doesn't snap into the mounting points spikeymike218 Bit Char-G Mods and Projects 18 02-16-2003 09:24 PM
