02-18-2005, 12:55 AM
yeah I've been meaning to get a pin vise, but have gotten around to it. Thanks for the tip.
02-19-2005, 11:05 AM
Obsessive Modder
There's supposedly a red texalium chassis in the works. Really interested to see pics of that. I bet it'd look sweet with the red anodized GPM parts sitting on top!
02-26-2005, 02:45 PM
Shhhhhhhh, how'd you know?
Limited run coming just for TRC, and I've got something else in the works for you li-ion/li-poly guys........................a.k.a. the "X+"
03-19-2005, 11:59 PM
well, I finally got the chassis made, well almost. I still have a couple more holes to drill and parts to cut out. What really pisses me off is my damn dremel drill press. The damn thing wiggles when I'm trying to get a precise hole made and causes the holes to be off ever-so-slightly.
I might have to make another chassis after I get a real drill press, but we'll see how this one runs when I get it 100%.
03-20-2005, 12:51 AM
Obsessive Modder
The new switchblade chassis is really nice-looking, although I don't like integrated top-bottom chassis' in general, as I like to use the GPM parts where I can for weight purposes (I actually like more weight for the handlign). It's just electric purple which is almost pink, so it's a bit too bright for me. I keep meaning to cut up a texalium sheet into a replacement chassis (I'm on the last leg of my chassis enhancements, with the electronics, ESC painting, and shinier chassis replacement all that is left.)
03-20-2005, 09:18 AM
CF is handful to accurately machine with common shop tools and attachments. After hand drilling the first 4-5 chassis with a titanium coated drill bit in a handheld bit holder and even trying an X-Y table with a small drill press, I finally broke down and bought diamond point bits. Fairly expensive, but when you mess up a chassis due to the bit wandering it is cheaper.
Horshu, I've changed suppliers for the Texalium, the sample chip I have is very nice.
03-20-2005, 09:54 AM
Obsessive Modder
Is your new texalium clearcoated on one side and dull on the other, or is it the red stuff? That's what mine looks like, with one side looking better than the tex chassis I got from your and other other looking much, much worse. I'm woefully behind on my waterjet cutting projects (foam for my XMODS briefcase and replacement/spare chassis'), so if another silver tex chassis or two comes available, I might just go that route.
03-20-2005, 11:53 AM
TinyRC & Mini-zRacer Fan
you can also look thru the tttt section as the 1:87 rcs use micro electronics (as small as they come)
03-20-2005, 12:15 PM
customanix
hey arch i know your big into the tttts but could uou maybe sugest a few small escs for us? i'm looking at some of the links from your sticky but i'm just not finding anything as small as im looking for.
03-20-2005, 01:24 PM
Is your new texalium clearcoated on one side and dull on the other, or is it the red stuff?....so if another silver tex chassis or two comes available, I might just go that route.
Red Texalium, had to buy a whole sheet to get the good stuff!!!!!!!!!!!!!!!!!!!!!
03-20-2005, 04:04 PM
Zero
Thanks for the drill bit tip I should be buying a drill press within the next week or so. The dreme drill press attachment has always caused me problems. One part of the press has play that allows the dremel to move side-to-side and I've tightned evry screw and bolt with no success.
CF is very tough I went through 3 Olson scroll saw blades, high quality precision ground blades too. Where can I buy those drill bits, Home Depot or on-line shops?
03-20-2005, 04:07 PM
Obsessive Modder
Red's a bit too far out of my color motif. The only deviations from silver I'll do are if a titanium chassis comes out (I'm actually surprised one hasn't shown up, since sheets are relatively easy to come by) and the mica blue paint job I'm doing to my ESC cover. Everything is silver (well, I just bought some blue and black wheels to go with two pairs of RS alloy wheels, so there's that, too)
03-20-2005, 08:58 PM
Zero
Thanks for the drill bit tip......Where can I buy those drill bits, Home Depot or on-line shops?
Try Harbor Freight. Not as costly some quote "Hobbyists" tool suppliers. They have identical equipment to a leading online hobby tool supplier at a much lower price.
Horshu, yeah, a contrast between hardware and chassis is nice, make sure you post your newest project!
