01-15-2005, 10:51 PM
Free suspension upgrade
Im not sure if this has been posted before but i was noticing how sad the stock springs are on the xmod and i didnt want to pay all that money for the radio shack upgrade,, I decided to just modify the stock springs:
Here is what you do:
Remove the springs, then just pull on them a bit until they just about double their length,, then re install them,, much stiffer and the best part,, FREE!
Im sure after a while they may return to close to the origional stiffness but so far they work awsome
Sporttracguy
01-16-2005, 08:03 AM
nice idea , sportracguy , i might aswell try that , as i dont want the full suspension i just want stiffer springs in the back ,
cheers man u helped :P
01-16-2005, 09:24 AM
Thanx alot...I've been thinking of buying the kit from RS for stiffer shox in the rear, but now don't have to!! You just saved me some money man! THANX
01-16-2005, 11:42 AM
not a problem, i figured i would save someone some money,, that radio shack suspension upgrade is way over priced for some cheap springs and a couple of different colored shocks in my opinion
sporttracguy
01-28-2005, 09:10 AM
Go me...
i actually did that ages ago. WOW, what a difference!
02-01-2005, 08:25 PM
duh
doing that will make your back wheels go like this \ /
LEIK whys you maek fnu o my speelin?
02-04-2005, 03:56 PM
Re: duh
The RS upgraded springs do that too.
350Z X-Mod
Stage 2 motor, suspension & steering,
lights, all wheel drive, alloy wheel nuts,
CF Driveshaft, Wide Track Bearings, GPM front knuckles, GPM 0 toe steering plate, GPM front upper plate, RS wheel & tire package, GPM Rear upper plate, GPM rear cup joints and axles
02-10-2005, 12:15 AM
just don't stretch them to much.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-24-2005, 09:09 AM
hmmm, i should try that
I hope you like the back of my car, cause you'll be seeing it alot.
02-24-2005, 11:13 AM
I stretched my spring when I did the monoshock upgrade.
03-05-2005, 04:35 AM
boro dori style RC
if you guys if you guys have braces or a friend with them and have the right size rubberband things.. you can slip them on the upper part of your shocks so your springs push into them. they compress the spring more.
the rubber might also absorb vibration and shock? probably not a significant amount though.
r34 - rwd
r34 - awd
dd4 - fwd
06-01-2005, 05:25 PM
Skyline=Sweet
haha...RS springs R better anyday
and they dont cost much at all!!!!!!!!!!
A wise man once said:
"Supras are red, Civics are blue, but pick the one that best fits you."
