Old 02-27-2005, 09:41 PM
Xtremekrawler8 Xtremekrawler8 is offline
Send a message via AIM to Xtremekrawler8
ZZSE Electronics On A ZZMTz?
Hey Guys,
I Was Wondering If You Could Put ZZSE Control Board Into A ZZMT. I Could Upgrade The Steering Servo Later. I Pretty Sure It Can Be Done But Would The Higher Torq. Motor Fry The FETs In It.
Also Could A ZZMT Be Used To Make A TTTT Truck. It Would Save Me A Lotta Work To Build One Than Start From Scratch.
I Posted The Question In The TTTT Forum But No Answer.
NATE
If It Cant Be Fixed With A Hammer Its Not Worth Fixing
Old 02-28-2005, 04:36 PM
mshkttck's Avatar
mshkttck mshkttck is offline
1. no
2. yes
Old 02-28-2005, 05:14 PM
then why cant i put se electronics in a MT?
Old 03-01-2005, 11:30 AM
viperdout's Avatar
It's Really Fast!
The reason is not because it can't be done but because of the SE limiting power (depending on the SE, it could only have 20% of power going to the motor). If you do Codesuidae's DC mod, that'll fix that problem, but at that point, it might be easier to just use an Iwaver board.
Project Bad Brushless:
Just say no to giant sigs.
Old 03-01-2005, 04:51 PM
Where Can You Buy The Iwaver Board Or The Mini-z Board At?
Let Me Check Tower But I Dont Think They Have It.
Does Anyone Have One They Can Sell To Me?
NATE
Old 03-01-2005, 05:52 PM
viperdout's Avatar
It's Really Fast!
NATE
Talk to Draconious over on tiny rc's sister site, www.mini-zracer.com . He's a mod over there and has a lot of parts.
Old 03-03-2005, 11:29 PM
codesuidae's Avatar
codesuidae codesuidae is offline
Send a message via AIM to codesuidae
The primary reason to not put SE electronics into an MT is because SE electronics cannot easily be used to do non-propo steering. The SE board must be used to run a steering gearbox with a steering potentiometer for feedback. That makes it difficult to fit into an MT (and expensive if you don't happen to have a junk SE).
You can do it, you just have to go all the way and do a monster truck with propo steering.
Without the DC mod it will have less power, but if you tricell or li-poly it this won't be a problem, it'll have plenty of power.
Old 03-04-2005, 06:21 PM
viperdout's Avatar
It's Really Fast!
I thought the SE had some way of limiting voltage. It's been awhile, so I can't remember if that's right or not.
Old 03-04-2005, 09:11 PM
codesuidae's Avatar
The SE controls voltage to the motor using a PWM drive signal, but a FETted SE it is capable of delivering just as much current as a FETted MT (presuming the same battery and a DC mod, without the DC mod it will deliver 56% the current because of the limited duty cycle)
Standard electronics swap? bluemonster XMODS 0 06-15-2004 12:51 AM
Building a truck with Epoch electronics? Sm0lders TTTT 6 03-02-2004 02:17 AM
Basic Electronics codedat XMODS Parts and Hop-Ups 4 03-01-2004 03:34 AM
4.8 Volt ZZSE urbanavenger ZipZaps SE 2 10-03-2003 12:13 PM
Did some comparisons between ZZSE / Bit Clones today... ax0n ZipZaps SE 9 09-30-2003 06:27 PM
