Old 12-24-2004, 11:28 AM
freakerz
Steering Knuckle Trimming
So I was visiting AtomicMods.com, and wanted to try there Steering Knuckle Trimming. But they had a warning about cracking the knuckle, so I find a easier way, and it takes 5 minutes to do it.
The concept is found on this page:
http://www.atomicmods.com/How_To/XMO...e_Trimming.htm
Do not use anything else shown on the page.
Here's what you want to use:
- Stone drill bit(to sand down the plastic)
- Drill(to operate the above item)
That's it... no need to use pliers and stuff.. the stone drill bit costs like 2-3$.. and you might even have one at home already!
Old 01-08-2005, 09:30 PM
J-Tuner's Avatar
J-Tuner J-Tuner is offline
i used a dremel the cutting wheel attachment. it only took me about 3 minutes.
I hope you like the back of my car, cause you'll be seeing it alot.
Old 01-09-2005, 02:26 AM
ChenPokoMasteR's Avatar
ChenPokoMasteR ChenPokoMasteR is offline
A Winner Is You
Send a message via AIM to ChenPokoMasteR
i did mine with finger nail clippers :P
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
Old 01-09-2005, 09:51 AM
mastersmite mastersmite is offline
May the force be with you
Send a message via AIM to mastersmite Send a message via Yahoo to mastersmite
This looks like that would not help you turn tighter or faster, and that would void the warante/ get you kicked out of teh XRL. personally i would not do it unless you don't give a _____ about the XRL, or have extra knuckles such as from the AWD kit.
Moege die Macht bei dir sein
Yellow 2004 NSX
Stage 2 Blue 11tooth SB hybrid
blue springs in back, yellow in fornt
AWD
Ball DIfferential
Duct-tape Autobra
Old 01-09-2005, 05:16 PM
I have a beach ball...
Did anyone here actually race in the XRL? I didn't find out about the one that was supposed to happen here until a month after it happened. It never was posted on the website, either.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
My Xmod mods livingplasma XMODS Mods and Projects 1 12-10-2003 12:49 PM
Need a left steering knuckle Tee Bee ZipZaps SE 8 12-06-2003 02:14 PM
How do you remove the front pins from the steering knuckle tjmon Bit Char-G / MicroSizers 14 02-17-2003 03:55 PM
