12-27-2004, 01:06 AM
the internal antenna is crazy, where did you get it?
12-28-2004, 12:56 AM
SkyineRC Pro
i made the antenna, out of cat.5 wire...really simple...works and looks better than stock
-1999 Nissan Skyline GT-R 34
-Paint in the works
-Airbrushed Wheels(stock)
-Mesh Front Grill
-Stage 2 SB Hybrid Drift Motor (8 tooth)
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
12-28-2004, 03:55 AM
boro dori style RC
Originally posted by Murcielago659
The main problem with this mod is that in certain situations, no power gets sent to the wheels at all. The case just spins around the discs. This is why you must do it in an AWD application, otherwise you'd never get anywhere.
heh. i just put washers into my gear differential (no gears pulled out). it pushes the sidegears against the casing causing an lsd effect. its not the disc mod you are mentioning. sorry for all the misunderstanding. and i do run it rwd. i've tried the disc mod you are mentioning and it sucks in 2wd..
for stiffer suspension you could try finding a good sized washer or something to serve as a perch for the spring on the shock (kinda works like not seating ur springs all the way). basically puts more preload on it. the extra stiffness does put more stress on the plastic chassis parts though...
skyline_69: what kinda paint did you use/prepwork/etc?
r34 - rwd
r34 - awd
dd4 - fwd
12-28-2004, 03:40 PM
Obsessive Modder
What would be the results of playing with different combos of diffs in an AWD vehicle? I tried front and back open diffs and am currently running with 2 ball diffs. Only odd performance I'm getting right now running on a very smooth, large surface is that it will go straight for about 5 feet and then jerk right a bit, leading to a lot of adjustments. Running both open diffs on an asphalt road ran pretty good, but going straight with no steering had the car kinda weaving left and right. I'm curious about other combinations, but I don't want to dismantle my suspension too many times.
01-04-2005, 04:48 PM
SkyineRC Pro
i used normal flat black spray paint just the regular kind you can buy at walmart or anywhere....and i mixed some pink paint in my airbrush for the rims...there was really no prep work other than masking the windows...i removed the head and taillight lenses so they wouldnt get paint on them...and then just about 5 light coats with 30 minutes between each...
by the way, i got a few more mods for x mas...awd, cl light kit, underglow, and 6 cell....pics will be up soon
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-04-2005, 09:53 PM
SkyineRC Pro
my lights...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-04-2005, 09:55 PM
SkyineRC Pro
underglow
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-04-2005, 09:56 PM
SkyineRC Pro
6 cell installed...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-04-2005, 09:57 PM
SkyineRC Pro
perfect fit
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-07-2005, 09:17 PM
SkyineRC Pro
i just polished my motor....
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-11-2005, 07:32 PM
SkyineRC Pro
Well, i almost ran out of ideas for my car, but i've finally come up with it....ALL GPM...i want to buy all billet gpm parts(a arms, shocks, decks, knuckles, axles, the works)...this next project is gonna take me awhile because of the cost of gpm parts....if anyone knows where i can get cheap gmp parts, please let me know, or if anyone has any parts they are willing to sell...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
01-16-2005, 08:36 PM
that nice modding, good i deas, almost best i seen so far
01-16-2005, 09:40 PM
SkyineRC Pro
thanx....next up are a few more simple things...im going to do the tight turns mod...and im workin on a way to fix the slack in the steering...just till i get my gpm stuff...ill post pix as i go...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
