12-24-2004, 05:57 PM
help my nsx!!!!
ok ... just got my 4th xmod and it was the nsx..... i put the upgrades galore up there (suspension, stage 2 motor, bearings, lights, underlights)... I finish and for the first test drive ... turning works fine... motor doesnt seem to work.......i need help i changed the motors 4 times.. everytime if i hold it, when i pull the acceleration the motor gives a lil movement inside that u can feel if u only are touching it....(I need punctuation i know)
12-24-2004, 09:46 PM
Anarchy 4-Ever!
check to make sure the D side of the shaft is properly connected. if not it may be holding the gears from moving....
Flat Black Supra
-Engine
Stage 2 Drift motor
-Exterior
Flat Black Custom Paintjob
Blue EL wire underglow (ordered)
Command Logic Lights (x2) foglights & extra taillights...
5Zigen Wheels
-Other Mods
AWD
12-25-2004, 05:53 AM
its not that.. whenever i pull the trigger, themotor doesnt even spin
12-25-2004, 11:20 AM
Banned
its prolly binding, take the motor out and see if itll spin, if it spins freely, then its a binding /gear alignment issue
12-25-2004, 12:22 PM
already tried ... still.... no car movement
12-25-2004, 03:15 PM
Anarchy 4-Ever!
take the motor out and plug it in but dont mount it just hold the sprocket and see if it has any resistance and see if it spins.... your electronics may be damaged...
Flat Black Supra
-Engine
Stage 2 Drift motor
-Exterior
5Zigen Wheels
-Other Mods
AWD
12-25-2004, 04:58 PM
lol
he did that just spun the motor without the gears and its jerks and stops i know this is funny but, batteries?
mini z:ferrari f-40
xmod:body undecided
12-26-2004, 12:27 PM
Banned
check if something is disrupting the motor
12-26-2004, 02:50 PM
5Zigen
Check if the leads are soldered in good on the PCB.
Try And Sleep Now.
DRIFT my ANTI-rice
12-26-2004, 09:45 PM
Make sure your batteries are good. I had some batterys new from the pack bad and my xmod did the same thing. Put good batts in and she ran.
12-26-2004, 09:48 PM
yea
i bought dead batts once! it happens a lot (ace not such a helpful place)
mini z:ferrari f-40
xmod:body undecided
12-28-2004, 02:04 PM
well, i took it to radio shack and it was the batteries, thx guys but now i can put the body up there to close it up now.... grrr
