Go Back   TinyRC.com > 1/43 and Smaller > SuperSlicks > SuperSlicks
Old 12-22-2004, 03:52 PM
skyline7 skyline7 is offline
Light removal?
Ive i want to remove the lighting system off my WRX can i do that, just take it off the body, will eh car still work even tho stuff isnt connected.. rather not there? And would my run time be longer? thanks
Super Slicks WRC WRX
Hard tires
Blue motor and Gearing
Stretched antenna for
better range
Old 12-22-2004, 07:21 PM
Loganberry Loganberry is offline
i think its just a small difference in run times with the lights on. i just un swrewed them and ripped em out. i think i could put them back in but have to tape them on to the body. if you had a lot of time you could bend the connector things in but i tried and it took to much time. later
xmod:acura nsx
zzmt:bigfoot - motors and tires
Old 12-24-2004, 09:39 PM
xThaiTX xThaiTX is offline
ya u can take off the lights if u like and it will still work. the contacts are just for the lights nuthing else. so if u dont want the lights then go ahead and take it off. if u want the lights and dont want to take it off but then again dont want the light to be on sumtimes then take a peace of paper and put it above the contact and the lights would not be turned on
my name is ThaiT and no im not from Thailand
Old 02-11-2005, 03:10 AM
sporttracguy sporttracguy is offline
or you can just bend the prongs back so they dont make contact and if you ever want them you can bend them back.
LEDs dont draw that much current so i dont think your run time will be that much different but its worth a shot
Add light set to your non ZZSE bodies! 'Vette Nerd ZipZaps 1 08-29-2006 05:18 PM
need some info about light kits bengali548 XMODS Mods and Projects 3 08-03-2006 12:44 AM
Light lens removal? (paint prep) Exaran XMODS 1 12-30-2003 04:45 PM
how to light up your xmods interior without buying a kit rpm XMODS Mods and Projects 2 12-27-2003 09:44 PM
Help with head/tail light installation BCGMan Bit Char-G Mods and Projects 10 01-04-2003 07:39 PM
