12-20-2004, 11:06 AM
3D Racer
I think I noticed something
Has anyone else noticed a resistor that is directly in the path of the negative terminal's conection. If I were to remove it would more power go to the board?
If it ain't broke make it better
12-20-2004, 11:26 AM
Gerbil Racing
looks like it but that might let too much power go to the board and fry it
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
12-20-2004, 11:54 AM
SkyineRC Pro
you would have to desolder the resistor from the board(leave it connected to the battery wire)...then you would have to use a multimeter ( like this )
and test the voltage and amps coming through the resistor, then desolder the resistor completely and test the volts and amps again but without the resistor.....i think these board can only take 8.4 volts max(without FETs)...so if you've got more than that without the resistor then you should leave it in there
-1999 Nissan Skyline GT-R 34
-Paint in the works
-Airbrushed Wheels(stock)
-Mesh Front Grill
-Stage 2 SB Hybrid Drift Motor (8 tooth)
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
12-20-2004, 08:10 PM
I think it's a 5.1v zener diode.
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
12-21-2004, 11:21 PM
Its a 240k (or 240 ohm I can't read the damn meter) resistor. Its dropping the voltage from 6v to a safe voltage for the board. The resistor can go on either the Positive or negative side, either way it's still dropping the voltage to a safe level
12-21-2004, 11:36 PM
3D Racer
so...... should I try it? cause if it is just dropping the voltage then if we removed it we could use less batteries to power it thus dropping weight.
12-22-2004, 12:51 AM
SkyineRC Pro
would probably reduce your runtime if you reduced the number of cells...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
12-22-2004, 11:04 AM
It's a zener diode then. There's one on the board, just most people don't figure out where.
Mods:
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
12-22-2004, 10:21 PM
3D Racer
dude the cells are wired in a series and each has its own mah and b/c of that it would not reduce run time
12-22-2004, 10:23 PM
3D Racer
what does a zener diode do?
12-22-2004, 10:32 PM
Limits voltage input. Essentially it's a glorified resistor, but there are differences. It only lets a certain amount of current out, no matter how much input there is, until the voltage peak is reached, at which point most (but not necessarily all) of the voltage goes through. Works on the zener effect.
http://www.americanmicrosemi.com/tutorials/zener.htm
Mods:
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
