Old 12-11-2004, 11:43 PM
proob4's Avatar
proob4 proob4 is offline
Master of R/C
Send a message via Yahoo to proob4
My micro drag car!(must see)
This is a Beta verion of my car. My next step is to stretch the chassis and body and add more battery cells.
let me know what you think?
If there is no attached pic goto this URL.
http://img28.exs.cx/img28/8159/microdrag39aw.jpg
Old 12-12-2004, 06:59 AM
bdnunchaku
Looks alright, although I doubt you would win any drag races with those rear wheels. You would have no torque due to the weight of those muscle machine wheels and the extremely hard plastic provides no grip.
Here's an extended bit drag car by crazydave:
http://www.tinyrc.com/forums/showthr...ighlight=video
You can see by the video that the wheels are extremely critical at those speeds along with the weight of the car. He added four zipzap se batteries to achieve 4.8v to the pcb. This car looks a lot more proportional to a real drag car and performs like one also. My suggestion is to find some better wheels before you start modding the chassis. What good is having a drag car that spins out and can't even finish a race?
Old 12-12-2004, 08:16 PM
proob4's Avatar
Master of R/C
Actually the wheels are not plastic they are rubber.They are really not muchheavier than the stock ones.In fact they are a hybrid of both stock and the other.
Old 12-13-2004, 02:08 AM
bdnunchaku
Really? If they are rubber then that may work pretty well for 3.6v and higher. My mistake...they really look like the muscle machine wheels. If they are the muscle machine wheels, I guarantee that they won't work for anything faster than a stock bit unless you have some high grip surface (like rubber mats).
Old 12-13-2004, 02:03 PM
proob4's Avatar
Master of R/C
They are off a muscle machine.And they are rubber. If it came down to a traction problem i could just use 2 sided servo tape and remove the glue from one side with lighter fluid.Then they would have plenty of traction.Cause the tape is baically foam rubber. But thanks
Old 12-14-2004, 03:13 AM
bdnunchaku
When you add more batteries, get the zipzaps se batteries. They are NiMH rated at 1.2V, 70maH and more importantly, they are much shorter than the standard bit battery (10mm dia x 10mm lg). Each zipzaps se battery contains two of these batteries soldered together (by a clip) and shrink wrapped.
Using these batteries is also the easiest way to dual-cell a bit. You simply cut the shrink wrapping down the center of the battery, so you can bend the soldering clip allowing the batteries to lie side by side. Just solder two wires to the batteries and they slip inside the chassis (between the steering system and the original battery location) with no problem. Then you simply solder the wires to the charging contacts.
Old 12-14-2004, 12:51 PM
proob4's Avatar
Master of R/C
Thats a good tip thanks.You say these cells are available separately or woud i have to buy and destroy a new zipzap?
Old 12-15-2004, 04:49 AM
bdnunchaku
This is from the faq section of zipzaps.com:
Where can I buy a replacement battery for the ZipZaps chassis?
Calling 1-800-THE-SHACK is the fastest way to find the batteries you need. Ask for RSU #12413449, 1.2V Ni-MH 1/4 AAA Battery or RSU #12413456, 2.4V MINI Battery.
You want the 2.4v mini battery. I bought three for friends a while ago for $12 including shipping (you can buy only one). Here's a link with the specific mod that I described previously:
http://www.bitmod.de/index.php?optio...d=84&Itemid=61
You can obviously see that if you did this mod with the stock batteries, your bit body won't fit because it sits much lower than the trueno. That's where the 4mm shorter zipzaps se batteries have an advantage allowing all bodies to fit after the mod.
Attached is a pic of a quad cell zipzap se from bdebde which shows the battery split and taped together:
Old 12-15-2004, 04:50 AM
bdnunchaku
Here's a pic from crazydave showing two zipzaps se batteries that are uncut:
Old 12-15-2004, 06:52 PM
proob4's Avatar
Master of R/C
Ok this is the latest on my micromod.This is the chassis stretch. I should have room for 4 nimh cells.The stock one has plenty of room with the stock cell size.
BTW You can click on these pics for a larger veiw
This is the body after the stretch,It has not had the putty fill,sanding or painting yet.But it looks promising.
Thanks for the info on the cells,Have you ever seen my other projects? Below is a link to my webpage. You can click on any of the images like the mini black mostertruck(canned heat mod),or the big pic with the 3 cars on it is a image map.That means you click directly onto each car to go to its own linked page. I hope you enjoy it. And thanks again for the info
http://www.geocities.com/proob4/bobspage.html
Old 12-16-2004, 04:36 AM
bdnunchaku
Most impressive! I would also recommend using larger stock cells if you have the room (especially when you peak charge). Post the finished car when you have it.
Also, my Motorworks dual-celled bit's time on a 7ft (kitchen floor)drag race is .81 seconds. But my car is for track races rather than drag (it has to take turns well). When you finish your car, let's see what crazy times you can get!
Old 12-19-2004, 09:03 PM
proob4's Avatar
Master of R/C
Hey Little buddy!
Can you tell me if radio shack can order them and if you know what the item #'s are.
thank's
Old 12-19-2004, 09:10 PM
bdnunchaku
Hey Little buddy!
thank's
Yup they sure can! Here's the info from radioshack.com:
Call 1-800-THE-SHACK
How many cells are you planning to add? You have a heck of a lot of room in your chassis! Holy crap, the speed of your bit is going to be insane. How many cells do you think it's going to take to cut my 7ft drag time in half?
Post the pics when you have them!
Old 12-20-2004, 11:03 AM
bdnunchaku
I also have spare motorworks front tires that I can send you if you'd like. They are slicks and have a round profile that looks more like a drag car. The pic from crazydave shows the wheels on his bit.
Old 12-21-2004, 08:39 PM
proob4's Avatar
Master of R/C
I got this the other day for $3.99 at this store kinda like a biglots called mazzels. I just was thinking if i could come up with some kind of mod for it? Any ideas? I was thinking maybe mix it with a bit and make a trike or something?
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 01:21 AM
TinyRC Bit Drag club (TBDC) Comrade_Boris Bit Char-G / MicroSizers 2 11-12-2003 12:12 PM
rtr hpi micro rs4. spy esc, 2 bodies, plus extras isk8blind For Sale/Trade 0 08-31-2003 05:38 PM
MY Custom Micro RC Story JadeFoxx Bit Char-G / MicroSizers 5 12-28-2002 10:57 PM
Canadian Micro Grand Prix lornecherry Bit Char-G / MicroSizers 9 10-03-2002 02:36 PM
