Old 12-20-2004, 11:32 PM
nfurby nfurby is offline
Drifting tips
Any one out there willing to share tips on how to set up a drift xmod? So far I have a skyline w/ bodykit and drift tires. Planning to get 4wd and 2nd stage motors. Any comments?
Old 12-21-2004, 12:19 AM
tigger94 tigger94 is offline
cut = custom
Send a message via AIM to tigger94
thats the setup im pretty much runnin . except i got a mono shock in the rear yellow springs all the way around and SB mags in the motor
Old 12-21-2004, 01:07 AM
I have a beach ball...
http://www.starterupsteve.com/swf/posting.html?
Replace "Steam Forum" with "TinyRC Forum" and you'll get the idea.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 12-21-2004, 07:27 PM
ChenPokoMasteR's Avatar
ChenPokoMasteR ChenPokoMasteR is offline
A Winner Is You
Send a message via AIM to ChenPokoMasteR
Also counter steer while your drifting
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
Old 12-22-2004, 12:00 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
here u go
i would say that if ur using an xmod u will have a hard time ripping the wheels off for a peel out so i would say get the drifting kit from radio shack and find the motor with as much torque as possible i heard the spinbrush mad works but i never tried since i am upgrading to mini z i will have to change this technique but wen i first started i did it on hard wood floors that i cleaned before starting:
step 1: clean floor
2: set up your car(super torkey motor, hard tires or taped tires, and a hard suspension in back and soft in front)
2: start out by doin single turn drifts for practice, as you come into the turn let off the gas about half way.
3: while your slinging around the turn with the momentum of the car at half throttle press the throttle all the way.
4: after you reach the point where you want to stop drifting let go of the throttle a little and the tires will regain grip.
5: coast out of the turn slowly accelerating and ur done!
DO NOT AT ALL PUT IT IN REVERSE!!!!! drifting was made so u dont loose too much speed around turns with a torky motor pressing the brakes and then gunning out of the turn will result in DONUTS.
mini z:ferrari f-40
xmod:body undecided
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Drifting an Xmod rody XMODS 1 01-01-2007 09:25 PM
radioshack racing series tips 10_second_supra XMODS 24 02-22-2004 11:32 PM
duall cells for drifting boho Bit Char-G / MicroSizers 10 07-14-2003 08:37 AM
