Old 12-18-2004, 05:22 PM
jeremy_n jeremy_n is offline
Universal Body Mounts
Hey all,
I've been working on a couple of different bodies for my long chassis. Most of the mods are incredibly easy to do. The one I've been having the most problems with is mounting the rear part of the body to the chassis. However, I think I have come up with a fairly simple way that should work for most model bodies.
Unfortunately I don't have any pics yet because I've had trouble finding the kind of plastic I want (living in Canada can suck sometimes).
Now for this mod you will use a normal RS rear clip. I'm talking about the black thing at the back of the RS bodies that goes down through the chassis and then you secure underneath. I hope that description is clear enough.
Note: This is much easier to do if you leave the windows out until all the fabbing is done.
Now, you need to make sure everything is measured out because fitment is important. Now, what you need to do first is make sure the body is sitting how you want it. Then mark the sides of the inside of the body where the hole for the rear clip is in the chassis.
This is the point that you need to mark on the inside of the body:
Old 12-18-2004, 05:24 PM
This is where you should mark it on the inside of the body:
Old 12-18-2004, 05:30 PM
Then what you need to do is cut a piece of plastic that will run from one side of the body to the other. Make sure when you do this that you have the rear clip already clipped into the chassis so you can determine the height of the plastic, because most car bodies are curved from top to bottom so if you just pick a random heighth then your plastic will most likely end up being to short or too long. Then attach the plastic to both sides of the body and attach the rear clip to the piece of plastic.
Use whatever size plastic you want and secure it however you want. I use model epoxy which is fairly sticky stuff. You shouldn't have any problems with the components in the rear of the chassis because the way the rear clip sits when it is secured should leave the plastic well above all the rear components. I hope that helps someone.
Old 12-21-2004, 12:33 AM
punkrockpimp
thanks, that helped me, ive been wanting to do a custom body but no clue on clips, got anything for the front?
Old 12-21-2004, 02:10 AM
I have a beach ball...
I think you could do something similar for the front. Just put a little strip of plastic down the middle and make a slot in it for the tab on the front.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 12-22-2004, 11:54 AM
That could defintitely work. The way I did this one is quite simple... The bumper that came with the model kit had a hole in it (looks like an opening to allow air to an intercooler or something) so I just centred the tab in there and epoxied some plastic on both sides so that when it is in the hole it is snug. I just happened to luck out that doing this made the wheels line up in the wheel wells but Murcielago659 is right. The same principle can definitly be applied to the front.
I'm glad that this helped. I was hoping someone would benefit from it. Let me know when you get it done!
Fast=Good
Fast=Money
Fast=FUN!
Old 12-22-2004, 03:22 PM
Glad I could help.
'65 Ford Mustang
All the RS goodies
Old 12-23-2004, 02:42 AM
Where would you mount them?
'65 Ford Mustang
All the RS goodies
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 01:19 AM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 02:48 PM
Body mounts chameleo78 XMODS 3 02-03-2004 12:53 AM
Homemade Z-Car BitCHarG universal body adaptor? pineapples10 Atomic Z-Cars 2 12-11-2002 06:25 PM
body mounts was ist los? ABC DTM SP 1 08-25-2002 02:46 AM
