Old 12-12-2004, 08:05 PM
catbed catbed is offline
Brighter Lights
This is how u make ur LED lights brighter on a ZZSE.
take tape and aluminum foil and cut it into squares. tape it over the lights.
Old 12-13-2004, 11:17 PM
damootch's Avatar
damootch damootch is offline
Exclamation
Wouldn't the foil short out the lights? I am not sure how much current goes to the lights, but the foil could ruin the car.
-Mootch
Old 12-14-2004, 02:55 PM
nope
it made mine at least 30% brighter
Old 12-15-2004, 12:00 AM
damootch's Avatar
On that note- 'Mod' well done!
-Mootch
Old 12-18-2004, 11:34 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Just be sure you don't allow contact between the leads of the LEDs and you'll be ok. It is possible that short circuiting could occur later from the foil moving around so you are taking a chance if you don't insulate the leads before installing the foil.
I'd suggest painting the area around the LEDs black and also liberally coating the exposed areas of the LEDs leads. This way the light is restricted from shining through the hood and fenders of the car as well as avoiding burning out the LEDs later through a short circuit.
Old 12-18-2004, 12:19 PM
Sdog's Avatar
Sdog Sdog is offline
Send a message via AIM to Sdog
Holy big photo! you might want to consider decreasing the size of your images before posting them.
BOURBON TIME OUT!
Command Logic Lights MODS drewdown84 XMODS Mods and Projects 4 07-30-2007 01:33 PM
RX-8 with lights. Widsinator ZipZaps Monster Truck 1 11-15-2004 01:41 AM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
running lights from car battery esp rocker Bit Char-G / MicroSizers 4 06-24-2003 01:23 AM
putting lights in my car xatu Miscellaneous Discussion 12 06-04-2003 12:06 PM
