Closed Thread
Old 12-11-2004, 11:42 AM
chooch chooch is offline
are two of these small enough to fit under my rsx xmod because they look the same as the ones atomicmods are selling?im looking in putting 2 of them in my xmod. also can you solder to these batterys or will it just slip off like a regular battery?
heres the battery http://www.batteryspace.com/index.as...ROD&ProdID=989
thanks
and is this a good charger for them ?
http://www.batteryspace.com/index.as...OD&ProdID=1121
  #17
Old 12-11-2004, 12:53 PM
LiLStagg LiLStagg is offline
No
People have tried to use them, they just Dont fit. And dont cheap out on a charger, get the 25 doller one atomic has.
  #18
Old 12-11-2004, 01:36 PM
dragon4450's Avatar
customanix
wow this thred got big fast. but i guess thats what its like when people act like 5 year olds. "i'm right" "no, i'm right" "no i'm right". fighting on the net is like compeating in the specal olympics, even if you win your still retarded.
anyways. it will never in a million years matter how many mah a battery has cos that only refers to the capacity of the battery and how long it will last. and last time i checked people were just putting on cells that came to 8.4v. if an xmod cant take more then 7.6v then how are people useing these with no problems? i know alot of people that just put on the cells with a stage2 motor and nothing has happened to the xmod except it went really fast.
chooch,
what body do you have on your xmod? that will greatly change what batteries you can or cant use. alot of the skinny bodies such as the supra and the corvette have a hard time fitting these cells.
and guys lets try to act a little more mature here. calling people names makes the forum look bad, and it will cause people to not want to come here anymore.
  #19
Old 12-11-2004, 02:16 PM
im going to use a rsx body
? will it work?
  #20
Old 12-11-2004, 05:56 PM
any one will these cells fit?
and why is that chager bad its a smart charger they say?
  #21
Old 12-11-2004, 09:44 PM
rs2000's Avatar
rs2000 rs2000 is offline
Xmodder
Send a message via AIM to rs2000 Send a message via Yahoo to rs2000
They look like AA size, if you can split them up they will probably fit under certian bodies. Or, you may be able to mount them right over the electonics up in the top of the body, but the high CG might be bad. I've seen people fit AA size batteries in their cars in the back. If you can get a hatchback that you like from a mini-z car and follow the tutorial they should fit nicely, and look cool!
*Nissan 350z*
[COLOR=royal blue]
-IC-3 800 mAH bats - 4 cell
-AWD
-Locked rear diff for drift action!
[/color]
  #22
Old 12-11-2004, 11:53 PM
These cells will not f**king FIT! but fine, don't listen to me, buy them and waste your money. Go ahead and Be my guest.
  #23
Old 12-12-2004, 05:06 AM
rs2000's Avatar
Xmodder
I didn't say they would fit without modification.. Jeeze, wasn't aiming the post at you anyways. No need to get so angry over it....
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
  #24
Old 12-12-2004, 02:44 PM
Phred168 Phred168 is offline
My ****ing god folks. For the last time, li-ion batteries are 4.2 volts NOMINAL. as soon as ANY kind of load is placed on them, out put is reduced to 3.6-3.7 volts... ffs.
1997 Red Toyota Supra (It finally bloody runs!)
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
Closed Thread
mah in a epoch theone&only.... Epoch RC1/43 3 06-07-2004 11:22 PM
needed: a few 150 mah batteries Rmc0130 For Sale/Trade 4 08-08-2003 11:22 AM
150 mah recharge rexdale_hacka Bit Char-G Parts and Hop-Ups 3 04-05-2003 01:41 PM
Testing mah. xatu Bit Char-G Mods and Projects 8 04-04-2003 05:45 PM
hmm.. how come the 150mah batteries r smaller than the 50 mah ? karlos Bit Char-G Parts and Hop-Ups 2 12-05-2002 08:39 AM
