Closed Thread
Old 12-10-2004, 02:18 PM
chooch chooch is offline
is the more the mah the better
is the more the mah the better? becuase i found this kit and its 2000mah ? heres the link tell me if there a good buy or not
http://www.batteryspace.com/index.as...OD&ProdID=1209
Old 12-10-2004, 02:58 PM
ninja828 ninja828 is offline
well, the more mah, the more current, but 2000mah would most likely kill your xmod by frying your fets. i know the fet board that jshwaa sells can handle currents like that if i rememeber correctly
Old 12-10-2004, 03:01 PM
LiLStagg LiLStagg is offline
LOL MAH the more the better, i heard those dont fit. and they WONT fry fets only if you have to hot of a motor.
  #4
Old 12-10-2004, 03:09 PM
CAN somebody tell me the best site for cheap li ions i need then desperatly.
  #5
Old 12-10-2004, 03:22 PM
rs2000's Avatar
rs2000 rs2000 is offline
Xmodder
Send a message via AIM to rs2000 Send a message via Yahoo to rs2000
Umm, WRONG. First off, the mAH is the battery capacity, but you can fry the board with a stock motor. If you run over 6 cells you will fry the board. This is because of the higher voltage that the stock board wasn't meant to take. I don't know too much about fets, but the info I stated is correct as far as I know.
*Nissan 350z*
[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action!
[/color]
  #6
Old 12-10-2004, 04:49 PM
WRONG! I have been talking about fets for a about a year now, i KNOW FETS control the motor! The ONLY way you can blow your FET's is if you have YOUR MOTOR draw to many AMP's. It does not matter how many batterys AS LONG as the motor does not draw more then 1.8 amps. You CAN run a stage 2 motor with lithium ions in it, or even with a 6th Cell.
Also, do not exceed 7.6 volts from an Xmod, you have a very high risk of it blowing the electrionics.
Ok so lithiums with a stage 1 or 2 motor, is FINE.
  #7
Old 12-10-2004, 04:55 PM
rs2000's Avatar
Xmodder
Ok, you may have been talking about fets for a year now, but obviously don't know, that when you fry your electronics by adding too many batteries and upping voltage, that you are burning out your fets. I know, my friend has a 4 cell li-ion car and had to put new fets in to handle the voltage, it puts out aroun 11 or 12 volts i believe.
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
  #8
Old 12-10-2004, 05:14 PM
You dumbass, if he has 4 lithums he NEEDS A VOLTAGE REGULAOR! quite bull****ting.
  #9
Old 12-10-2004, 05:19 PM
my question was is 2400mah to large? will it fry the xmod
  #10
Old 12-10-2004, 05:21 PM
tehre to large to fit, no if you run a stage one or two it wouldnt fry. No matter how many MAH they wouldnt fry. Its only the amount of amps being puller, or not to go over 8.4 volts.
  #11
Old 12-10-2004, 11:21 PM
rs2000's Avatar
Xmodder
Right, like im a dumbass . Anyways, he had them wired in series at 12 volts and then put them in parallel so he gets a TON of mAH, and now runs a mamba brushless system with all 4 in series.
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
  #12
Old 12-10-2004, 11:27 PM
rs2000's Avatar
Xmodder
Sry, forgot this one. Yeah, dont listen to LilStagg, you can have a trillion mAH and your car wont fry. Its the voltage and current draw that will fry your car, just make sure that the batteries will fit inside the car before you order them.
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
  #13
Old 12-11-2004, 12:22 AM
Phred168 Phred168 is offline
Glad to see the world is full of idiots. Voltage will only fry your FETs if the V(max) of the FETs is exceeded, which is usually 20-60 volts, far more than most people are going to throw at an xmod (6 cell li-ion... in parallel). Current draw is the ONLY thing that will fry a FET on anything like a normal xmod. Voltage destroys the zener diode on the board, which is what limits on board voltage to 5.1 volts, thus not allowing ANY current to pass across it. That's pretty much the only thing voltage will damage, unless there's enough of it to cause an arc across the board's traces or melt the glue that holds the traces on.
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
  #14
Old 12-11-2004, 12:46 AM
rs2000's Avatar
Xmodder
WRONG! I have been TALKING about fets for a about a year now.... It does not matter how many batterys AS LONG as the motor does not draw more then 1.8 amps....
Also, do not exceed 7.6 (I thought it was like 8.4?) volts from an Xmod, you have a very high risk of it blowing the electrionics.
Meh, if im an idiot, than the world is full of them.... at least im not alone....
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
  #15
Old 12-11-2004, 08:14 AM
Dude I AM saying THOSE WONT FIT
Closed Thread
mah in a epoch theone&only.... Epoch RC1/43 3 06-07-2004 10:22 PM
needed: a few 150 mah batteries Rmc0130 For Sale/Trade 4 08-08-2003 10:22 AM
150 mah recharge rexdale_hacka Bit Char-G Parts and Hop-Ups 3 04-05-2003 12:41 PM
Testing mah. xatu Bit Char-G Mods and Projects 8 04-04-2003 04:45 PM
hmm.. how come the 150mah batteries r smaller than the 50 mah ? karlos Bit Char-G Parts and Hop-Ups 2 12-05-2002 07:39 AM
