Old 11-09-2003, 08:42 PM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
x speed motor mod
I installed the xspeed motor in my xmod. On first installation I matched the positive and negative wires to the xspeed motor in the same place the wires are on the xspeed motor out of the package. Once installed the car went in reverse when I pulled the trigger on the control and then forward when I applied the brakes. I just reversed the wires on the motor and now it works fine. Now (after the wires have been switched) when I go in reverse (the origional forward for the xspeed) the car moves faster than when I go forward. I think this is because the motor is running backwards as to the way it was meant to run. Any ideas on how I can solve this? Any way I can get the motor to run in the direction is was meant to run?
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-09-2003, 11:24 PM
neurokinetik's Avatar
It's a timing issue. I'm not sure how to solve it at this point. The motor runs with advanced timing in one direction, and retarded timing in the other. I've been seeing the same behavior in other Mini-Z motors as well. Usually the timing is adjusted by rotating the endbell (and brushes) relative to the motor can.
Here's a thought...
Maybe the motor shaft could be forced out through the end bell, and the pinion mounted on the endbell side instead, which would allow the motor to run in the proper direction. The mounts would need to be revised in order to make this work.
Old 11-10-2003, 03:49 PM
Morphes Morphes is offline
kinda the lazy way out of the problem but u could just reverse the body and run in reverse and have backwheel turn! how much are those xspeed motors?
Old 11-10-2003, 04:10 PM
The xspeed motors are between 15 and 20 dollars depending where you go. I paid 19 and change for mine.
Thanks for the replies guys. I added 2 more cells to the car and it is way fast now. I think if I fixed the motor problem it would be too fast to control.
What I will try however is one of the tamiya motors maybe the ultra dash or the plasma dash. Can anyone offer some advice on this upgrade before I try it? I worry about the FETs being able to handle these motors. Other people have posted that they installed these motors just fine, but failed to mention if they upgraded the FETs or not.
Xmod Skyline
9 tooth Drag gears
6 cell mod
AWD
RS Bearing Set
Old 11-11-2003, 09:58 AM
I just made a couple of discoveries last night.
1. The problem with going faster in reverse than forward may not be the motor at all. I didn't check my X Speed, but all my other motors run the same speed in both directions, which indicates "neutral" timing. The problem lies in the mechanics of the car, causing more friction going forward than reverse. With one of the motors I was testing, I swore there was a timing problem, but there really wasn't. It's the drivetrain.
2. Timing can be advanced, yielding nice gains. I have a stage 2 motor that runs just as fast as my X Speed now. Maybe faster. How did I do it? By adjusting the commutator on the armature. Not a new trick by any means, but one I hadn't ever tried before.
So, the only thing I have left to do is to test my X Speed in an unloaded condition and see if it indeed runs differently in one direction than the other. If it does, I now know how to fix it.
Old 11-11-2003, 12:00 PM
cisco cisco is offline
How do you adjust the commutator on the armature?
Old 11-12-2003, 11:35 AM
I just used a pair of needlenose pliers and ever-so-gently twisted the commutator in the proper direction. Since these motors spin clockwise, (as viewed from the pinion gear side) to advance the timing, you would twist the commutator in the clockwise direction. It is important not to use the pliers directly on the commutator contacts, but grip using the collar closer to the armature windings.
You don't need (or want) to twist very far, and I wouldn't do this on a motor that you can't afford to ruin. It is best to experiment on a stage 1 motor or one of those $2.99 jobs that RS sells, until you get the hang of it. Many things can go wrong when you are disassembling and reassembling the motor. You can mess up the brushes, pop the bearings out of the motor can or misalign them, all of which will make you slower than when you started.
Last night, I performed this operation on the X Speed motor, and it now spins faster in the forward (clockwise) direction than reverse.
However, I messed up the brushes a bit, so it isn't running quite as strongly as it should be. Oh well, time to sacrifice a stage 1 motor... :lol:
Old 11-12-2003, 01:27 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
you got any pics to show how you did it? i wanna try this on the stock motor but i'm only 95% sure of what to do, i need you for the other 5%
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-12-2003, 02:43 PM
I just bought a set of stage 1 motors, plus one of those $1.99 motors for testing. Perhaps I'll make a "Motors 101" guide.
Old 03-21-2004, 01:54 AM
xxxmod xxxmod is offline
Open the moter & switch mags around. prob. solved
Old 11-21-2004, 04:44 AM
Rodrick Rodrick is offline
I know this is a real old post but if reversing the wires will make the car run correct why not solder red to red and black to black and keep in mind you need to push the throttle forward to go forward. No one will want to drive your car cause it will confuse them.
MY WIFE GAVE ME A CHOICE. THE R/C HOBBY OR HER...SHE'LL BE MISSED.
Old 11-21-2004, 05:19 PM
newbitowner's Avatar
the kyosho xspeed motor can be used on a stock xmod?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 11-21-2004, 05:44 PM
thats what im reading newbitowner the guy at my LHS told me it should be faster than the stage 2 motors but i think they are the same turn (49 i think) but dont quote me on that.if they the same turn i dont see how is it faster
Old 11-28-2004, 10:27 PM
hotrod29728's Avatar
hotrod29728 hotrod29728 is offline
Send a message via AIM to hotrod29728 Send a message via Yahoo to hotrod29728
Probably the Polarity of the motor needs to be switched just flip the magnets around... Had the same problem... As for the Xspeed being faster I'm sure it's the quality of the winding (hand as to machine) and the magnets.... Hope this helps...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 11-28-2004, 10:33 PM
no mod fets are reqiured?
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
SE 1/4 mile speed tests Steve ZipZaps SE 8 02-08-2006 03:04 PM
The Infinite Speed Potentiometer Mod (tm) actofgod Bit Science 46 09-16-2003 05:47 PM
speed speed speed ml22 Bit Char-G / MicroSizers 6 03-14-2003 01:27 AM
modified a body to fit Speed Racer Spec 1!! nojodash Epoch RC1/43 0 01-18-2003 10:16 AM
2.2 2 speed vs 2.6 1 speed eman1 Bit Char-G / MicroSizers 0 12-16-2002 09:34 PM
