11-15-2004, 01:32 PM
Need Help
Hi everyone, does anyone know how to remove the gear on the rear axle? I tried to pry it off but that didnt work.
My cars- (Both are Super Bit Char-gs)
Honda NSX-R red with white stripes
1.6 motor
Spring suspension
Soft tires front
Hard tires back
Red neon
Body lowered
Nissan Skyline GT-R (New R34)- Silver+Blitz Skyline Decals and paint
1.6 motor
Spring suspension
All soft tires
Blue neon
Body lowered
Blitz Skyline Bodykit
11-16-2004, 06:49 PM
BitPimp
when i removed my rear rims, i took the tires off, grabbed the rims and twisted em... the side with the gear should break loose first... then just do the same to remove the gear.
i removed my rear axle rim and gear to be able to put my ball bearings on it.
and to put em back on... just super glue em, remember not to use too much cause you'll never get it off then.
Whack!
11-16-2004, 11:30 PM
Tool User
Take a pair of pliers, grab the axle, remove the tires, then gently start to twist the rims off, the gear comes off the same way.
And as always, installation is antidisassemblywise.
why are you trying to take off the gear?
11-17-2004, 12:43 AM
Do you getto dremel?
do as is stated above but you have to be careful and go slow. i broke two gears trying to get them off to put on the offroad axel for my dead monster truck project.
11-18-2004, 06:22 PM
I am trying to get the gears off from my clone because I need them to fit on my super bit char-g.
Still trying to get them off.
Oh yeah, I gave away my Skyline bit char-g to my little brother. The steering is all messed up. I opened the front up but there was no problem. The magnet is not crooked or anything but it is not centered (not the magnet but the plastic the houses the magnet), therefore creating a bad steering. Fine tuning it just isn't enough. so I was hoping that you guys can help me.
1.6 motor
Spring suspension
Soft tires front
Hard tires back
Red neon
Body lowered
1.6 motor
Spring suspension
All soft tires
Blue neon
Body lowered
