Old 11-17-2004, 07:22 PM
Rodrick Rodrick is offline
Question SB Hybrid Motor Question
Do anyone know how much faster my Xmod will be with the SB Hybrid Motor mod?Right now I have the stage two 10 tooth motor,bearings,awd,carbon driveshaft,and the 6 cell mod. Do anyone have a SB Hybrid Motor for sale.I have two stage 2 motors and the spinbrush motor but I dont wanna spend 15 bux for a pinion puller when I can just buy a new motor for 15-25 bux with the pinion already installed.
MY WIFE GAVE ME A CHOICE. THE R/C HOBBY OR HER...SHE'LL BE MISSED.
Old 11-17-2004, 08:09 PM
rob3662 rob3662 is offline
I'm kinda new to x-mods, but my understanding of the effect of the spinbrush magnets increases the torque and not the speed, but maybe it will be able to get closer to the top speed of the motor with the sb magnets. Also I was reading that you can switch the magnets without taking out the armature, there is a tutorial on another forum on how to do it. Hope it helps
Old 11-17-2004, 08:14 PM
I'm new to Xmods too,I read the magnets gives more torque but that should increae my top speed a lil bit if not I think I 'll just a new motor. I want to get around 17-20 mph at least.
Old 11-17-2004, 09:42 PM
rssjib rssjib is offline
Too many XMODS
What are you using the car for? If it is a short track, then an eight-tooth would be sufficient and you would want more torque. It it is a long track, then a 10-tooth would be good and you would want the power for good top end.
20 mph would be okay, but not necessarily so for a long track.
Good luck, bro.
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 11-18-2004, 09:56 AM
I'm not really in to racing .I just find a large flat surface and play.I'm saying I want at least 20mph cause my 1/10 scale car and truck are doing high 20's and mid 30's so I'm just used to speed.
Old 11-18-2004, 01:33 PM
Too many XMODS
One of my Skylines has Li-Ions and an AtomicMods SS130 with a 10-tooth in it. It probably runs about 30 or so, but is way hard to control at that speed. If you turn too hard, it flips! But it hauls in a straight line.
RSSJIB
Silver RSX: stocker
Old 11-18-2004, 03:17 PM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
Re: SB Hybrid Motor Question
send me your two motors...I'll do the pinion swap for ya....
the SB motor needs to be wired up backwards from the S2 motors
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
Old 11-19-2004, 10:12 AM
thanx Skurge420 i just found this chart so I think it will be cheaper for me to just sell my motors on ebay and buy a new motor thats better than the Sb mod or just buy the Sb motor with the pinion already attached.I saw some somewhere for I think 15 bux shipped.I should be able to get around 10 or 12 bux for my motors including shipping.
Old 11-19-2004, 11:38 AM
Skurge420's Avatar
Gerbil Racing
that will work too.....lol
The SB from what i've heard isn't much faster....just more acceleration
I have a SB motor at my house....i've just been to lazy to hook it up
Mini Cooper Mini-Z
Old 12-01-2004, 12:32 AM
inott40's Avatar
inott40 inott40 is offline
TinyRC Pimp
Send a message via AIM to inott40
i built a sb/stage 2 hybrid a while back. had more torque. top-end stayed the same.
too much to list..
Old 12-01-2004, 01:25 AM
Skurge420's Avatar
Gerbil Racing
now i'm curious.....i'm gonna hook up the SB motor this weekend
Mini Cooper Mini-Z
Old 12-14-2004, 08:02 PM
skyline_69's Avatar
skyline_69 skyline_69 is offline
SkyineRC Pro
Send a message via AIM to skyline_69
i did the sb hybrid on a stage 1 white motor...and the torque difference is outstanding....that thing flies off the line now...and it makes for awesome slow show drifts
-1999 Nissan Skyline GT-R 34
-Paint in the works
-Airbrushed Wheels(stock)
-Mesh Front Grill
-Stage 2 SB Hybrid Drift Motor (8 tooth)
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
Old 12-17-2004, 01:41 PM
n2o_matt n2o_matt is offline
Send a message via AIM to n2o_matt
Re: different engine?
Originally posted by Stanley10101
You do know that you can put the magnets in your same motor with a tiny flathead screwdriver and some small pliers right? I tested my sb magnets in a stage 1 motor and it took me like 5 minutes to install and switch back to normal.
all you gotta do is bend the plastic cap on the motor up, pull out the clip holding in the magnets, slide out both magnets (mark them so you know which side is which) slide the new ones in, insert clip, bend down the plastic, use flathead to bend metal back over plastic to secure it, and your done.
you can even do the same process and put the xmods magnets back in the spinbrush motor and reassemble the sb.
I did this mod last night, but it took me like 30min not 5. Everything was easy except geting that U pin that holds the magnets in place out.
After this point ALL problem were my own faulty ability to work with tiny stuff:
Other than that it was easy - well till i jacked up one of my brushes while trying to pry out that freakin U clip. I ended up breaking the copper strip on the brush trying to get the right contact patch on the com Since its my only motor i said wth and soldered the accual brush back on the copper peice and then tried my best to get the contact with the com right - it was still way off but i put it back to gether and it accualy ran!
Now i did this with the stock motor that came with my xmod. I had advanced the timing and was able to beat my friend's stage2 topspeed motor in a drag race.(he did have AWD tho) I thought that timing gave you rpm but i took him off the line every time and his top speed was just a hair faster than mine. Now i'll have to race him with my "stage1 advtiming-SB-gettobrush" and see how much the crappy brush job is hurting me. - but it feels about the same.
Some day i'll fork out the cash and get the stage2 and do the same mods - minus the getto-solder-brush deal
Old 10-24-2005, 08:25 PM
kabootle kabootle is offline
I built a SB hybrid by putting SB magnets in my Stage 2, 10 tooth (2 EZ) One point I'd like to make is DON'T CHANGE THE WIRING. If you put the magnets in the right way, it with run the right way. Changing the wiring messes up the timing a little bit. This car runs like a bat out of hell (considering how much I've spent). I'm so cheap though, trust me, if I could afford it, I'd go full out with Li-Ions and FETS and fatboys from atomic mods
I AM ME. DONT'T LIKE IT? EFF YOU!!!
cooler SB hybrid motor ViperKid XMODS Mods and Projects 12 02-03-2004 07:36 PM
SB hybrid.. 93Supra0wner XMODS Mods and Projects 0 01-15-2004 10:58 PM
s2 / SB hybrid joe_t1g XMODS Mods and Projects 10 12-27-2003 04:06 PM
My latest hybrid motor godsmistake XMODS Mods and Projects 2 12-11-2003 05:55 PM
