10-17-2004, 02:08 AM
iPod therefore iAm
MicroSizer/Bit Char-G Plane/Other stuff
I've searched Google, I've searched forums, and I can't find anything. I want to make a plane out of my MicroSizer... but I can't find out how! I also need to know how to do a multiple cell mod, multiple motor mod, MOSFET mod, and the Li-Po mod. I want to make a MicroSizer plane but I would like to put a FET stack on the PCB and use the fastest & highest torque motor possible. Is 4.2 the highest? (I know I've seen it somewhere... just can't remember where) I would also like to supercharge my MS Pro by adding a FET stack, Li-Po's atleast 2 motors, and maybe 2 or 3 cells. I searched so please don't tell me not to search!
10-21-2004, 03:30 AM
BitPimp
in reply to mat paintball guy
man it seem as tho these forums are dying down... probably cause school/college is back in play.
im working on a new controller using two 556 dual timer chips for proportionate steering/throttle, i hope it works... cause ive only got two cars and ones already scrapped. if this thing works it would be the most kickinest remote for even micro-flight.
i just need help designing the pots/switches used for em. i was thinking an old play-station joy stick should be the trick, but id rather have two sticks for better control.
if anyone has any suggestions here please help me out. i just got into this micro stuff a couple days ago so im kinda new with it all.
and i need a couple questions answered: are normal bits moddable to be a turbo car... i mean add a third chanel? and why are the bcg's still so expensive when the clones are around 5 dollars?
Whack!
10-23-2004, 02:00 AM
iPod therefore iAm
Okay... I need to know how I would go about doing this project. How many motors do I need? I think going with 4.2's... Okay so far this is what I know I need to do. Increase the range by removing the "cripple capacitor," wire up 2 or 3 4.2 motors, and add a steering mechanism. How do I make the plane steer if a BCG steers using magnets??? I still don't understand how to convert a magnet moving from side to side to a rudder, ailerons, flaps, and an elevator moving up/down/left/right. I just wish TinyRC was as active as Mini-ZRacer...
10-24-2004, 11:38 PM
iPod therefore iAm
The post on the German website said that the owner of that Bit Char-G is running a carbon chassis. Does anybody know where I can get a carbon chassis for cheap, or like can I make one or something? Also it said he was running ball bearings. Anybody know where I can get/make those?
10-26-2004, 08:05 PM
iPod therefore iAm
Thank you. Nice video! I was thinking of using a 4.2 high torque motor (I don't have a pager, I will be ordering 4.2's anyways, and I don't want a pager) So would a 4.2 work? And where can I get LiPoly's that small and chargers?(hopefully for tiny and bigger LiPoly cells) And how do you get an actuator to work? All I know is that you wrap copper wire around something and like you glue it every X amount of wraps, then once the glue is dry you take out the little thing you wrapped it around. Then somehow a magnet goes in between it and this is the point where I get lost because of breif descriptions...
10-27-2004, 07:16 PM
iPod therefore iAm
I was reading something on motors, and it said that the 4.2 motor's torque was 39 newton per meter... what does that mean? And weirdly, the 3.8 motor had lower torque, 35 newton/meter... What do these numbers mean?
10-27-2004, 08:47 PM
The 4.2 has more power than the 3.8 is basically what those numbers mean.
The best choice of motors in respect to indoor planes and bit gear is probably the 4.5 ohm 6mm didel pager motor.
10-28-2004, 12:15 AM
BitPimp
where is it you get the props? and how do you mount them to the motor?
Whack!
10-28-2004, 10:18 AM
iPod therefore iAm
Bodie, there is no way I am getting a pager motor. I don't want a pager, I have no use for a pager. Is a 4.2 or a dual 4.2 enough to fly the plane pretty fast?
10-29-2004, 10:37 PM
Here's a few pics of my plane using bit radio electronics. Built from plans at E-Flight.
10-29-2004, 10:39 PM
10-29-2004, 10:40 PM
