Old 09-15-2004, 10:54 PM
Twenty-Se7en's Avatar
Twenty-Se7en Twenty-Se7en is offline
Re: I know why
Originally posted by Speedking221
I had the same exact problem the problem was that there was either hair behind the gear in the moter or behind the gear that the moter spins this happens to me all the time so I clean it out and then I get better run time i dunno If i am rite though
interesting... i have to try a few things but if they dont work out i'll check on that, thx
||| It does not matter if you win or lose. It only matters if I do. |||
Old 09-24-2004, 08:42 AM
ICEMIKE ICEMIKE is offline
RUN TIME
Here is the beef guys.
Get yourself a new car, or at least change the battery in the car so that is fresh. ( if it is questionable) Then you get yourself the X-mod rechargable AAA set. Not only do they have more mah's but you save a lot lf money on batteries. Once you have your X-mod batteries all charged up, put them in your SE controller and double zap your car. In other words put the car on, wait for green, pop it off and put it on again until green. NOW YOUR READY TO RACE! Your car will be faster and your run time will go through the roof. Like I said, you want to do this to a fresh internal car battery. This will set a good memory in the bat.
Believe it or not sometimes I get 20min. run time. I know you thinking no way. ITS TRUE! I sometimes turn my car over and run the battery out just because I get tired of driving it.
I have put many hours into the run time problem. Not any more!
P.S. Once you double zap your car for the first time I recomed doing this every time. I have never had any problems with this method. Now all my friends do the same thing.
And I only use the purple motor.
BAM, ANOTHER NOTCH.
Old 09-24-2004, 03:02 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
I just single charged my new GT and I am getting insane runtimes! Into 20 minutes if I don't hold the throttle at full all the time. I think these cars are getting much better! The worst I got was a few minutes on horrible batts.
longer runtime ? kcrzb ZipZaps Monster Truck 0 12-29-2005 10:08 PM
Runtime with a 7.2v and 180 motor? Anyone else use this setup? Truth ABC DTM X4 2 10-21-2004 02:25 AM
What's the runtime of an XMod? LCKKN]HT XMODS 5 02-05-2004 11:49 AM
improved runtime!!! gtr2112 Bit Char-G / MicroSizers 4 12-20-2002 07:44 PM
