Old 09-07-2004, 10:50 PM
SRTFAN SRTFAN is offline
Quick newbie question...
Hi Guys, I'm from Toronto and we just got the xmods here recently. I was bored at work and was thinking of buying a zipzap to entertain myself, and stumbled upon this forum. Lots of good info here...
Anyways, my question...I want to buy an xmod now, other than picking up the starter kit ($70 cdn) and maybe rechargeable batteries will I need anything else, will that be sufficient? I am not really looking into spending too much money right now, maybe keep everything within $100 canadian ($75ish US). Mods can come later.
Went by the local RS and they had a bunch of civics and two supras. Thanks in advance.
Old 09-07-2004, 11:09 PM
ax0n
If all you want is a car that will last a while, get the base car with rechargeables, and then the metal ball bearings. The plastic wheel bushings are weak and worthless. Mine were worn out in just a week or two.
Also, I'm not sure that the XMODS rechargeables and charger are the best way to go. you can pick up some IC3's and a charger for a bit more and it will charge a lot faster. I personally have a ton of NiMH AAA's, so I stick to my one-hour energizer charger.
If you have enough money left, for fun, I'd suggest stage 2 motors. The stock stage one gets off the line great, but after it's off the line it pretty much goes the same speed.
Old 09-08-2004, 12:56 AM
Thanks man. Where can I get the metal ball bearings from? I dont see them as an xmod accessory on the RS canada website. The stage2 motor is not too expensive, will probably get that.
Old 09-08-2004, 09:06 AM
ax0n
Someone could send you a set from the US, or there are other bearings that will work in the xmods. I can't remember if the tinyrc.com store sells them or not. Atomicmods.com has some for sale as well that are supposedly better than the xmods ones. I have had good luck with the radio shack bearings.
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 12:38 AM
Quick painting question Yaksha XMODS Gallery 2 01-08-2004 04:21 PM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
newbie question ViperKid Bit Char-G / MicroSizers 1 05-28-2002 08:15 PM
