09-05-2004, 10:08 PM
A bit of an odd question
While I was snoopin' around on allelectronics.com, I came across these motors:
http://www.allelectronics.com/cgi-bi...224&type=store
Basically, an in-hub electric motor. Any idea as to how they'd adapt to an xmod?
At 6 Vdc they turn at approximately 9700 RPM.
09-05-2004, 10:56 PM
Do you getto dremel?
i dont think you have a chance of converting them over to XMOD use. you could make a sweet quad motor RC car with them though just not in an XMOD
09-05-2004, 11:31 PM
5Zigen
They would run way too slow.
Try And Sleep Now.
DRIFT my ANTI-rice
09-06-2004, 09:45 AM
At 30000 RPMs (totally unrealistic) and the white pinion set(6:1), the wheels are spinning at 5000 RPMs. Thus, the question is more of fitment,power, and the like than whether or not it'll spin fast enough.
09-06-2004, 02:45 PM
5Zigen
You can maybe open up the motor, and see if you could attatch a pinion onto the wheel. (or if there is a shaft) I don't think it would fit in the motor bay to well though.
Try And Sleep Now.
DRIFT my ANTI-rice
09-06-2004, 06:34 PM
Never hurts to try  Maybe I'll order a set this week and see what happens.
09-12-2004, 08:32 PM
Go ahead and buy a set... Wire them directly into the motor wires and see what they do... Just mount them to the chassis were the old cups/joints/axles/tires would be... That would take alot of weight off of the car... Just try... You never know...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
09-13-2004, 05:16 PM
Ferrari rox and so do i
you shoyld buy 4 of them and use each of them as a wheel. get different wheels thing so you have grip and go. if would look like a futuristic car though
Skyline with RS graphics
All RS upgrdes
4.5 Stiff/front Medium/back
9 tooth drag motor
GTR Xtreme kit from cXp
Custom internal intenna
Custom lights with fogs and tailpipe
Mono-shock in rear
Red Ferrari 360 modena body in the works
09-13-2004, 06:31 PM
You really could only use two other wise you would need FETs to give it more current... And Li-Ions probably... Plus, how would you steer? I guess it would be primarily drag...
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
09-13-2004, 09:20 PM
Already have li-ions  And I suppose i could rig up a bit of an odd tierod system to use w/ the stock servo. Just mount the wheels like on the stock suspension, more or less. Not the actual suspension, of course, because extensive modification would be required. but at any rate, I wont be ordering anything until Ivan's blown by (I like in Panama City, Florida. Right in the middle of "You're screwed" alley)
