Old 08-29-2004, 12:06 PM
InspektrGdgt InspektrGdgt is offline
Broken Cups?
Is anyone with Li-Ion power knows the plactic Cup shafts in a stock Xmod are quite inadiquate. Lastnight after taking apart the right A-arms, to change out the cup joint again, I had a great idea to strengthen the cup joints.
I tightly wrapped the cup joint with dental floss then lightly covered it with super glue. After giving it about a half hour to set I gave the car a spin.
The car seemed to have more punch, and after hours of driving now the cup joint is still intact. Hope this helps as a cheap way to save cup joints.
Old 08-31-2004, 04:11 PM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
I had an idea similar to this as I rip at least one apart everytime i use my cars.....
i'll have to give this a shot
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
Old 08-31-2004, 07:53 PM
Yea it seems that for every hour of drive time I had at least one of those cups broke. But since I did this mod both fromt and back cups have been holding up.
Old 08-31-2004, 08:24 PM
Lucky7 Lucky7 is offline
If my motor is stock do I have to worry about breaking my cups?
Old 08-31-2004, 09:15 PM
SHIFT_DRIFT's Avatar
5Zigen
Not after many hours.
Stock as in Stage 1 or stock class? (+45 turn non-fet motors)
Try And Sleep Now.
DRIFT my ANTI-rice
Old 09-01-2004, 07:48 AM
Stock as in stage 1, right out of the package.
Old 09-01-2004, 04:49 PM
Clownn Clownn is offline
i herad in XMODWORLD that using heatshrink works also do you think it actually works?
350z
Weight Reducted Chassis
Weightless Driveshaft
5 cell
Stage 2 Yellow Motor
Custom Heatsink
Stronger Magnets
100µF Capacitor
Old 09-01-2004, 04:59 PM
hotrod29728's Avatar
hotrod29728 hotrod29728 is offline
Send a message via AIM to hotrod29728 Send a message via Yahoo to hotrod29728
I haven't heard about the heat shrink but, it sounds reasonable... As for the Stage I(box stock as referred to in slot car racing) you shouldn't worry about the cups for many many many hours of driving time... Usually you burn the internal parts up on a box stock before they break... Well at least for me anyways....
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 09-01-2004, 05:07 PM
Using Heatshrink
I have tried using heatshrink aroung the cups though for me it seemed to not work. My car runs for about 20-30 min on one charge using Li-Ions, after 2-3 discharges I would have to replace the heatshrink and after about 9-10 discharges I would have to replace the cups. So far I've discharged my car about 20 times, and the cups are still holding just fine.
Old 09-02-2004, 08:44 AM
maxximum attack
So if you're going to use Li-ions you should just buy metal cups?
What else would you have to get in order to run li-ions safely?
(in terms of motors and electronics)
Old 09-02-2004, 01:23 PM
ninja828 ninja828 is offline
yup, aluminum cups, joints, front decks, rear decks, knuckles, rims, nuts......aluminum EVERYTHING
Old 09-02-2004, 01:44 PM
Wish I had the Budget.
Is anyone making Alu dogbones yet, I heard that MIP Was willing to make them though they would need a very big preorder
Old 09-02-2004, 10:55 PM
maxximum attack
So how fast can 2 li-ions gat my xmod?
35+ mph?
Old 09-03-2004, 01:28 PM
35+ mph probably if you have a good setup....its all in your setup, but to get your xmod to go that fast, you'd probably have to use at least 3 li-ions...maybe...dont quote me on that. but you deffinately would need to upgrade your fets
Old 09-04-2004, 09:52 PM
viperdout's Avatar
It's Really Fast!
Just buy aluminum ones.
Project Bad Brushless:
Just say no to giant sigs.
pcb cover broken? frizzen ZipZaps Monster Truck 4 07-18-2005 02:55 AM
Metal*/aluminum/titanium/steel Axle cups QPizzle XMODS Parts and Hop-Ups 18 02-19-2004 08:56 AM
Help with broken car... skyline0276 Bit Char-G Parts and Hop-Ups 4 11-09-2002 10:48 AM
broken bit xsboost94 Bit Char-G / MicroSizers 2 10-01-2002 09:13 AM
Broken chassis BaliLover Bit Char-G / MicroSizers 7 07-14-2002 11:40 PM
