Old 08-14-2004, 01:34 PM
Sawblade's Avatar
Sawblade Sawblade is offline
Wheeeelie!
Good gear lube!
On my two older ZZs, I tried lubing the gears with a tiny bit of 3 in 1 oil. It worked good, but it picked up every bit of dirt & hair and needed to be cleaned often.
While I was turning the F-150 I just bought into a dually, I got a wild hair and stuck a pencil into the gears while they were spinning. It ground off a little bit of graphite and now it runs MUCH more smoothly than with the oil.
[Edit] BTW, I just held the pencil against the gears long enough to turn the teeth shiny black.
-=Sawblade=-
Wheelie poppin' Red ZZ F-150 - Rear soft microsizers tires, Front hard tires, beer keg tri-cell mod, anti-roll bars, wheelie bars, 1/8" body drop, rare earth steering magnet, dual return springs, steering stabilizer bar and spring suspension, 28K Orange ZZ motor, Red 12:1 gears, 22ga power wires, heatshrinked antenna wire, .
Old 08-15-2004, 03:20 AM
rfnagel's Avatar
rfnagel rfnagel is offline
Send a message via AIM to rfnagel Send a message via Yahoo to rfnagel
Another thing that works quite nicely is powered graphite (see the small pic at the bottom of this pic collage -> http://www.cmoo.com/~snor/weeds/zipz...race_cases.jpg ), although it can be quite messy.
Old 08-15-2004, 04:36 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Yup, the graphite is the way to go. You can get little tubes of the stuff were keys are made in department stores and home improvement centers. I douse the gears and wheel spin points with it and blow off the excess after working it a bit. Works great.
7 tooth pinion gear gtr2112 Bit Char-G / MicroSizers 12 10-11-2008 10:44 AM
Custom Crawler Gear Mod hartoy53 ZipZaps Monster Truck 3 06-30-2008 02:44 AM
different gear? ziggie216 Bit Char-G Parts and Hop-Ups 1 08-12-2002 02:01 PM
Gear Sets? kbtoyz902 Bit Char-G Parts and Hop-Ups 7 07-18-2002 01:57 PM
