Old 02-14-2004, 12:59 AM
darkjester darkjester is offline
Send a message via AIM to darkjester
Altezza light tutorial
well this is my car:
As u can see there are altezza lights. Its not really all that hard to make these, ive been meanign to make these for a while now but im cool and lazy like that.
ok heres the tut. ENJOY!
Materials needed:
paint thinner
1 small sheet of shiny material (foil, silver leaf, etc.)
i used foil for mine
1 razor (for cutting excess foil)
1 red Sharpie (its what i used)
ok now here are the steps
Steps:
Step 1: Separate your xmod body from the chassis
Step 2: Look at the back behind where the lights are located
You will see little plastic blobs that connect the lights to
the body. Take the razor (or however you want to take it
out) and cut out the plastic.
Step 3: Take out the lights. Make sure the little plastic rods are
intact, or you're screwed.
Step 4: Take the thinner and take out all the paint on the lights
Step 5: Take the red sharpie and color where you want the red
to be
Step 6: Get the sheet of foil and place it where the lights will go
on the body. So pretty much place the foil where the
lights are placed.
Step 7: Push the lights through the foil and back onto the body,
and now you should have foil sticking out of the sides of
the lights.
Step 8: Cut out the excess foil from the body
Step 9: Now you have Altezza Lights!
Note: the lights should fit properly without having to glue it back on because theres foil making it snug. But if its loose then glue it on
Old 02-14-2004, 04:06 PM
skklown skklown is offline
nice tuturial
xmod blue civic ricemobile.
Old 02-15-2004, 09:45 PM
thank you
Old 02-15-2004, 10:32 PM
newbitowner's Avatar
I found a product called goof-off that also safely clears out the lights.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-16-2004, 07:14 PM
yea tha works but i find paint thinner to be teh best
Old 02-20-2004, 01:01 AM
I found an orange sharpie from Wal-Mart. Here's euro lights with amber...
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-20-2004, 10:06 AM
good job. What happened to the paint on yuor trunk????
Old 02-20-2004, 07:08 PM
I ran 6 cells...
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 08-05-2004, 11:20 PM
AcuraPerformanc AcuraPerformanc is offline
If you use brake fluid it will safely take off the paint with out any hazin. just wash the lights with soap an water then do wat ever!
Old 08-06-2004, 10:56 PM
hotrod29728's Avatar
AcuraPerformanc are you sure its brake fluid instead of brake cleaner... Cause that is to completly diffrent things... I didn't think brake fluid had the right chemicals to dissolve the paint off the lights...OR maybe had TOO MUCH chemicals to dissolve the paint... But I dunno you tell me...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 08-08-2004, 07:28 PM
i dont know what kinda paint that is on there but i havnt tryed it. I know it works with moldels , I use brake fluid to strip the paint off and it works just takes a little time and then you have to clean it good with soap and water. Iwill try it and tell you how it works.
Old 08-08-2004, 09:00 PM
Okay thanks...
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
Old 08-09-2004, 03:51 PM
I did it today with brake fluid and it hazes the lights I didnt know that but havent found any thing to take the haze off so i dont think any one else should do this !!!
Old 08-09-2004, 05:08 PM
Okay thanks for the warning AcuraPerformanc and I hope you can find something that works... Like brake cleaner or finger nail polish remover...
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
Old 08-09-2004, 06:03 PM
I used Clear coat to clear up the hazin it sounds crazy but it worked ok there not as bad but not super clear like i wanted
Add light set to your non ZZSE bodies! 'Vette Nerd ZipZaps 1 08-29-2006 05:18 PM
need some info about light kits bengali548 XMODS Mods and Projects 3 08-03-2006 12:44 AM
how to light up your xmods interior without buying a kit rpm XMODS Mods and Projects 2 12-27-2003 09:44 PM
Light Coloring Tutorial ugh ZipZaps SE 10 10-18-2003 11:48 PM
Help with head/tail light installation BCGMan Bit Char-G Mods and Projects 10 01-04-2003 07:39 PM
