10-18-2002, 10:03 PM
SpeedFreak
how do you make plastic flexible? putty makes very smooth transitions from plastic to putty that are inivisible with paint.
10-18-2002, 10:59 PM
13B REW
well, plastic r always flexible just depends on which kind u use. the 1 i use is from my bit char-g case(the clear plastic that holds the bit) . well i find that very useful. ill post pics of my plastic bodykited rx-7 when im done, all i need now is black pactra paint.
10-19-2002, 12:43 AM
SpeedFreak
you mean lexan right? thats the stuff 1/10 rc cars use for bodies because it flexes and is able to absorb impacts.
10-19-2002, 12:47 AM
13B REW
lol, i dont know what kind of plastic i use , all i know is that i use the plastic from my bit chase ,the clear plastic that holds the bit and everything, or u can just find it anywere .
10-19-2002, 08:11 AM
smoove operator
henry, are you speaking of the packaging the bit comes in?
10-19-2002, 10:11 AM
Putty
was ist los?,
I'm trying to picture what you did...
I assume you placed the putty on the body then molded/sculpted it to the way you want. Let it harden, sanded it smooth and then painted. Correct?
The putty is on the body the whole time, right?
Also, what brand of putty did you use?
I've been wanting to make body kits for my Bits. After seening yours, I'm really inspired!
10-19-2002, 01:57 PM
da da dum da dum da da
weighing down the car some, wouldn't that be good if you had a 3.8 motor popped in
"Do you want a new Bit Char-G
WELL I DO TOO!!!!!!!!!!"-me
"i'll let you win, on one condition beat me"-me
racing down akina
10-19-2002, 02:05 PM
13B REW
kwikbb yes, the clear plastic.
first come the cardboard that shows the brand name and everythin, then its the clear platic holding the bits and stuff ,and thats the plastic i used.
10-19-2002, 04:11 PM
SpeedFreak
i feel so good that i have inspired some of you guys
DriveWRX: that is exactly what i did for my other body kits, but on this one, the front one came off so i had to glue it on after it hardened. then i sanded it. make sure not to have too much putty behind the body in the front, sides, or rear, or you will be unable to put back on the body. i used milliput epoxy putty(only one the store had). im sure any epoxy putty will do.
10-19-2002, 04:31 PM
smoove operator
Hey thats pretty resourceful henry... good thinking. Can't wait to see your rx-7.
10-19-2002, 10:17 PM
SpeedFreak
ok ive got LOTS of pics. clearer.
10-19-2002, 10:18 PM
SpeedFreak
top/slide
SpeedFreak
front
10-19-2002, 10:19 PM
SpeedFreak
rear
10-19-2002, 10:20 PM
SpeedFreak
top
