Old 07-18-2004, 11:49 PM
dietryin's Avatar
dietryin dietryin is offline
title? i dont have one!
Send a message via AIM to dietryin
ive owned two mr01's and both, ended up with cracked chassis...... well they were heavily modded lol... about 45mph each i kinda miss the handling and speed.. but xmods are more fun
just say no to big sigs
heh.. stolen from viperdout^
Old 07-19-2004, 10:43 AM
viperdout's Avatar
It's Really Fast!
Originally posted by jamiekulhanek
Oh god.........I am guessing you don't own a Z, right?? They are way stronger than XMODS.
If you cant get the solder to stick, you ain't doing it right.
Each surface (wire and battery surface) must be heated in order for the solder to stick, what you are doing is a cold solder joint, or dry joint, where there is a layer of flux under the solder. Meaning it has not bonded. When the cell surface is hot, the solder should 'flow', not go into a ball sitting on the surface.
You need a hotter iron or try heating the cell for a bit longer.
Ideally you need an extremely HOT iron for soldering cells, as it means the job can be done quickly without dmaging the cell from heat.
I hope you realise that those lithium cells aren't 4.2 v.... They may read that when they have been charged and arent being discharged. If you measure them under load they will only be around 3v each, or 18v for 6 of them.
Just a few tips to help.....
No, I don't own a Z. I haven't tried, but the company themselves said that the solder would not stick after a friend of mine tried it out. I also don't have a very hot soldering iron, but I got it for free, so it was perfect. Peak voltage on the cells is 4.2, straight off the charger. Nominal voltage is 3.7 volts/cell. The problem is, you'll still have 4.2/cell for just a little bit, thereby, you still need the strength of the board to hold that. BTW, if it doesn't go fast enough, I'm going up to 6 cells.
Project Bad Brushless:
Just say no to giant sigs.
Old 07-19-2004, 08:58 PM
jamiekulhanek jamiekulhanek is offline
Trust me, all cells have internal resistance, due to this resistance there will be a voltage drop under current load.
i.e. NiMH cells under high load drop down to under one volt under high load.
Solder will stick to any cell, you gotta have enough heat.
Old 07-20-2004, 10:23 AM
viperdout's Avatar
It's Really Fast!
Battery holders are cheaper than a new soldering iron.
Old 07-20-2004, 02:18 PM
dietryin's Avatar
go to RS and get a saudering kit, it comes with a 40watt iron ( relli powerful ) it also comes with a heat sink,sauder, and tools to help u hold wires etc. great buy for 10 bucks
Old 07-20-2004, 02:55 PM
viperdout's Avatar
It's Really Fast!
Nah, I have an iron (otherwise I wouldn't have made this baby), but for 5 bucks, it's easier to just buy battery holders.
Old 07-20-2004, 02:58 PM
dietryin's Avatar
do u have aim? if not get it ( http://www.aim.com ) and im me at BACKDR1FT
Old 08-08-2004, 02:17 AM
hotrod29728's Avatar
Wow Jay you make it sound like you telling the guy to get AIM... If you guys wanna Instant Message me @ hotrod29728 or Jay @ BackDr1ft ... We know a good bit about Xmods and can help out in one way or another...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
bitPimp's 4th Annual Year End Blow-Out DarkTari Bit Char-G / MicroSizers 2 10-07-2006 07:37 PM
4WD shaft mod + 180 motor mount cdog4w Mini-X 17 03-23-2004 06:46 AM
Stock rear end better? slotsurfer Auldey (All) 1 01-04-2003 03:26 PM
Mini x Loose Front End Hollywood Mini-X 4 06-15-2002 10:47 AM
